Hi, I’m trying to change the sshd.socket as the user guide document shows, but it’s not possible to change the file because the file system is mounted read only. I changed the partition label=system to readonly=false on partition.xml, but there was no effect. How can I solve this problem?
adb shell
mount -o remount,rw /
Thank you Keven,
I’ll test, but, I would like to know how to change that on yocto.
