Hello, I am looking to operate SC206E by connecting a 5V adapter to USB_VBUS and a 3.8V battery to VBAT pins and I have some questions:
When a 5V input is applied to USB_VBUS pin, can SC206E operate normally using the power from USB_VBUS pin while simultaneously charging the battery?
If that is the case, while SC206E is being powered by a battery through VBAT pins and I plug in the 5V adapter later, is there a seamless transition between battery and adapter? In other words, will SC206E operate without interruption when 5V is applied to USB_VBUS and will SC206E start to draw power and charge battery using 5V instantly?
Thanks in advance.
