SC206E EVB sim not recognized-
Hello Team!
Using QRBX210-RBX with SC206E firmware BP10.005. AT+CPIN? returns ‘SIM not inserted’.
qcrild is running. Which UIM slot is active on the carrier board and does it require any
hardware configuration (jumper/strap)? I already tried with both slots on the evaluation board.
Hi again for clairification:
I’m using a QRBX210-RBX module with SC206E firmware (baseband: BP10.005 /
SC206EEMNAR60A05), running Linux (Yocto build, kernel msm-5.4).
The modem is running and responsive, but the SIM card is never detected on either slot.
The SIM is physically inserted in the slot on the carrier board.
Diagnostics performed:
  1. qlril-api-test → QLRIL_GetIccCardStatus returns card_state: 0 (absent) on both slot 1
    and slot 2
  2. AT commands via qlril-api-test:
    AT+CPIN? → +CME ERROR: SIM not inserted
    AT+CCID → ERROR
    AT+CIMI → (empty)
    AT+QCFG=“simconfig” → +QCFG: “simconfig”,2,2
    AT+QCFG=“hotswap” → +QCFG: “HOTSWAP”,0,0
    AT+QCFG=“simInsertLevel” → +QCFG: “simInsertLevel”,1,1
  3. Changed simInsertLevel to 0,0 and rebooted modem with AT+CFUN=1,1 → still SIM not
    inserted
  4. Changed back to 1,1 and rebooted → still SIM not inserted
  5. Tried switching slots via QLRIL_SetSimCardSlotId(1) and QLRIL_SetSimCardSlotId(2) →
    card_state: 0 on both
  6. Kernel shows no UIM/SIM related entries:
    dmesg | grep -i “uim|sim” → (nothing)
    find /proc/device-tree -iname “uim” → (nothing)
    lsmod | grep uim → (nothing)
  7. qcrild service is running normally
  8. SIM card is confirmed working (tested in a phone)
Questions:
  1. On the QRBX210-RBX carrier board, is the SIM card slot physically wired to the SC206E
    UIM pins (GPIO 72-75 for UIM2 or GPIO 76-79 for UIM1)?
  2. Does the carrier board require any jumper, strap, or hardware configuration to enable
    the SIM slot?
  3. Which UIM interface (UIM1 or UIM2) should be used on this board?
  4. Is there a hardware design guide or schematic available for the QRBX210-RBX carrier
    board?
Thank you.
