reply:
Our SDK already has openssh service by default, you don’t need to add it. The command to connect to wifi is as follows:
/ # wpa_cli
wpa_cli v2.5-devel
Copyright (c) 2004-2015, Jouni Malinen <j@w1.fi> and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Selected interface 'wlan0'
Interactive mode
> scan
<3>CTRL-EVENT-SCAN-STARTED
> wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=CN
<3>CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=CN
<3>CTRL-EVENT-SCAN-RESULTS
<3>CTRL-EVENT-NETWORK-NOT-FOUND
> scan_results
bssid / frequency / signal level / flags / ssid
7c:d9:a0:0f:9a:32 5260 -53 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
7c:d9:a0:0f:9a:30 5260 -53 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
08:4f:0a:a7:32:90 5260 -60 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
08:4f:0a:a7:32:92 5260 -61 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
10:c1:72:1d:8b:50 5260 -63 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
10:c1:72:1d:8b:52 5260 -64 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
b8:e3:b1:12:72:62 5260 -65 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
b8:e3:b1:12:72:60 5260 -65 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
7c:d9:a0:0f:9a:23 2452 -44 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
7c:d9:a0:0f:9a:22 2452 -44 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
7c:d9:a0:0f:9a:20 2452 -44 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
08:4f:0a:a7:32:82 2432 -47 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
08:4f:0a:a7:32:80 2432 -47 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
48:01:c5:5d:4a:0c 2412 -50 [WPA2-PSK-CCMP][ESS] 12345
b8:e3:b1:12:72:53 2452 -59 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
b8:e3:b1:12:72:52 2452 -59 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
b8:e3:b1:12:72:50 2452 -59 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
10:c1:72:1d:8b:42 2432 -55 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
10:c1:72:1d:8b:40 2432 -55 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
44:6a:2e:13:cc:70 5260 -75 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
44:6a:2e:13:cc:72 5260 -76 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
7c:d9:a0:0f:96:a2 2412 -71 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF-2.4G
7c:d9:a0:0f:96:a3 2412 -72 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
f4:b7:8d:85:d4:b0 5260 -80 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
b8:e3:b1:12:7c:20 5785 -81 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
f4:b7:8d:85:d4:b2 5260 -81 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
10:c1:72:1d:32:c0 2432 -74 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
7c:d9:a0:0f:96:a0 2412 -74 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
b8:e3:b1:12:7c:22 5785 -82 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
b8:e3:b1:12:7a:10 2452 -78 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer-2.4G
f4:b7:8d:85:d4:32 5180 -89 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
f4:b7:8d:85:d4:30 5180 -90 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
44:6a:2e:12:0c:72 5180 -91 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
44:6a:2e:12:0c:70 5180 -91 [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS] Quectel-Customer
10:c1:72:1d:32:d2 5785 -93 [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS] Quectel-HF
> add_network
0
> add_network 1
3
> set_network 3 ssid "Quectel-Customer"
> set_network 3 psk "Customer-Quectel"
> enable_network 3
> wlan0: Trying to associate with SSID 'Quectel-Customer'
<3>Trying to associate with SSID 'Quectel-Customer'
> eap_proxy: eap_proxy_notify_config
eap_proxy: eap_proxy_allowed_method
wlan0: Associated with 7c:d9:a0:0f:9a:30
<3>Associated with 7c:d9:a0:0f:9a:30
> wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
<3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
> wlan0: WPA: Key negotiation completed with 7c:d9:a0:0f:9a:30 [PTK=CCMP GTK=TKIP]
<3>WPA: Key negotiation completed with 7c:d9:a0:0f:9a:30 [PTK=CCMP GTK=TKIP]
> wlan0: CTRL-EVENT-CONNECTED - Connection to 7c:d9:a0:0f:9a:30 completed [id=3 id_str=]
<3>CTRL-EVENT-CONNECTED - Connection to 7c:d9:a0:0f:9a:30 completed [id=3 id_str=]
> wlan0: WPA: Group rekeying completed with 7c:d9:a0:0f:9a:30 [GTK=TKIP]
<3>WPA: Group rekeying completed with 7c:d9:a0:0f:9a:30 [GTK=TKIP]
> status
bssid=7c:d9:a0:0f:9a:30
freq=5260
ssid=Quectel-Customer
id=3
mode=station
pairwise_cipher=CCMP
group_cipher=TKIP
key_mgmt=WPA2-PSK
wpa_state=COMPLETED
ip_address=10.66.178.122
p2p_device_address=00:0a:f5:43:11:6c
uuid =97b2bdeb-80a7-559c-8d76-b0f0ac40a881
> quit
/ # ifconfig
bridge0 Link encap:Ethernet HWaddr 4E:5E:D0:B3:7B:6F
inet addr:192.168.225.1 Bcast:192.168.225.255 Mask:255.255.255.0
inet6 addr: fe80::4c5e:d0ff:feb0:786c/64 Scope:Link
UP BROADCAST PROMISC MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:192 errors:0 dropped:0 overruns:0 frame:0
TX packets:192 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:12368 (12.0 KiB) TX bytes:12368 (12.0 KiB)
rmnet_data0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.64.88.16 Mask:255.255.255.224
UP RUNNING MTU:1500 Metric:1
RX packets:19815 errors:0 dropped:0 overruns:0 frame:0
TX packets:92682 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3163833 (3.0 MiB) TX bytes:24623631 (23.4 MiB)
rmnet_ipa0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING MTU:2000 Metric:1
RX packets:16798 errors:0 dropped:0 overruns:0 frame:0
RX bytes:3401613 (3.2 MiB) TX bytes:25365087 (24.1 MiB)
wlan0 Link encap:Ethernet HWaddr 00:0A:F5:43:11:6C
inet addr:10.66.178.122 Bcast:10.66.183.255 Mask:255.255.248.0
inet6 addr: fe80::20a:f5ff:fe43:116c/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:58 errors:0 dropped:0 overruns:0 frame:0
TX packets:25 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:16580 (16.1 KiB) TX bytes:2776 (2.7 KiB)
/ # ping baidu.com
PING baidu.com (110.242.68.66) 56(84) bytes of data.
64 bytes from 110.242.68.66: icmp_req=1 ttl=53 time =70.6 ms
64 bytes from 110.242.68.66: icmp_req=2 ttl=53 time =70.1 ms
64 bytes from 110.242.68.66: icmp_req=3 ttl=53 time =70.1 ms
64 bytes from 110.242.68.66: icmp_req=4 ttl=53 time =69.3 ms
