Hi everyone, just started my work with this kit and module. I installed RS232 driver and when I open port with QCOM it says the port was open successfully, but when I send commands it has no response. What other drivers I need to install and where could I find AT command manual?
Thanks in advance
You can use the following steps to send AT command;
adb shell
su
cat /dev/smd8 &
echo “ATI\r\n” > /dev/smd8
Thank you very much! I saw that people mostly communicate with bash commands, but I dont know how to do it. Is there manual or tutorial for it?
Can you able to use adb command on your PC?
If yes, you can execute the commands I provide first.
If there is no error, you can see the firmware version is printed by ATI command.
Could you send me win11 usb driver, I think that is the main problem?
You can downlaod driver from internet.
Maybe you can try this:
Downloads - ADB Driver Installer
