I just update the unpacking_tool to last one (SC200E_Android12.0_r004_Unpacking_Tool_20230208.zip) and now I’m getting this error:
[17:52:44] - ################################################################################
[17:52:44] - # update_common_info.PY - VALIDATING FILE PATHS
[17:52:44] -
[17:52:44] - update_meta: Verifying mandatory partition files against contents.xml
[17:52:44] - =====================================================================
[17:52:44] -
update_meta.py: FLAVOR - ASIC
[17:52:44] - Skipping partition file validation :[]
[17:52:44] - ------------------------------------------------------------
[17:52:44] - /home/sascar/Desktop/quectel/Unpacking_tool/QCM2290.LA.2.0/common/build/emmc/bin/asic/sparse_images/rawprogram_unsparse0.xml
[17:52:44] - update_meta.py: 27 files to check
[17:52:44] - STORAGE TYPE = emmc
[17:52:44] - *** ERROR: xbl.elf is NOT listed in contents.xml for asic flavor.
[17:52:44] - *** ERROR: xbl.elf please update the file element type of xbl.elf as download_file
[17:52:44] - *** ERROR: xbl_config.elf is NOT listed in contents.xml for asic flavor.
[17:52:44] - *** ERROR: xbl_config.elf please update the file element type of xbl_config.elf as download_file
[17:52:44] - Done
[17:52:44] -
Error:
File list validation check failed for mandatory files
Could someone help how can I solve this?
Another question at same topic. For SC200EEMNA 32GB/3GB I have to use this script “build_qcm2290_wtr2965_ddr4_64bit.sh” without parameters right?
I saw that inside old unpacking_tool there’re files inside folder BOOT.XF.4.1:
Newer unpacking_tool no files inside folder:
Leonardo
