Hi Team,
We are working on the Bluetooth interface of the SC200E-EM Module on EVK itself. And we are facing the connection issues as explained below.
Issue: When we try to connect the SC200E-EM with any of the Mobile phones, SC200E-EM EVK is able to list out the Bluetooth devices. After connecting with the devices, immediately disconnecting. And no suspicious logs are identified in the dmesg log or logcat.
NOTE: We have connected the on-board WiFi/BT, MAIN, DRX antennas as well. And build is generated from the default source code from the Quectel (Just downloaded and generated the build, No code changes are done from our side in the code)
Can you consider this as high priority and suggest some solution for this?
