Hey guys, I have a SC200E-EM module EVB kit with single touch screen. I was following the Quectel_SC200E_Series_Compilling_Burning_Guide_V1.0.pdf guide and had to compile bengal-userdebug but I don’t see it when I run lunch command.
3. Prepare the Android code, execute the following commands in the code directory to compile the
entire Android image package.
-Execute the following commands to compile the entire Android 11 image package:
After compilation, the generated images are in directory $AndroidCodeDir/out/target/product/bengal.
For 32go version, the generated images are in directory out\target\product\bengal_32go.
source build/envsetup.sh
lunch bengal-userdebug //For 32go version, the command is lunch bengal_32go-userdebug.
./build.sh dist -jn //n indicates the number of CPU threads
How to setup the android code properly?
Note:
repo init -u https://android.googlesource.com/platform/manifest -b android-11.0.0_r43 --depth=1
repo sync
This is how I repo init and fetch code, also is there any other source of bengal code?
