Dear all,
I’m trying to apply updates to my image.
I followed instructions from “SC20 OTA Firmware Upgrade Guide” document.
- Exported variable BUILD_NUMBER with value 200217
- Initial Release creation (removing some Apps from PRODUCT_PACKAGES list) : OK
- Exported variable BUILD_NUMBER with value 200218
- Created new release adding back apps into PRODUCT_PACKAGES list
I used the command described on document to create the Incremental Update file:
./build/tools/releasetools/ota_from_target_files -v --block \
-p out/host/linux-x86 -k build/target/product/security/testkey \
-i ~/work/projects/wellpay/android/dist_output.200217/msm8909-target_files-200217.zip \
~/work/projects/wellpay/android/dist_output.200218/msm8909-target_files-200218.zip \
~/dist_output.200218/update_200217_to_200218.zip
But downloading the ZIP file and requesting Android to install it, the terminal reboots and stay on Recovery:
adb devices
List of devices attached
(no serial number) recovery
The terminal stays in this state until I run an adb reboot command.
After reboot, I check the /cache/recovery logs. In last_log I see:
[ 3.668211] Update package verification took 1.0 s (result 0).
[ 3.685756] Installing update...
[ 3.763162] sysutil: mmapped 1 ranges
[ 3.787476] Source: qcom/msm8909/msm8909:7.1.2/WPBRv1.0/200217:userdebug/test-keys
[ 3.787628] Target: qcom/msm8909/msm8909:7.1.2/WPBRv1.0/200218:userdebug/test-keys
[ 3.787728] Verifying current system...
[ 4.430583] partition read matched size 16979240 sha d72afbcf01f011ca65dfb0d2725d670067c8ecd1
[ 4.458989] 253632512 bytes free on /cache (56713216 needed)
[ 29.495295] performing verification
[ 29.515865] blockimg version is 4
[ 29.515995] maximum stash entries 99
[ 29.521228] creating stash /cache/recovery/2bdde8504898ccfcd2c59f20bb8c9c25f73bb524/
[ 29.522996] 253628416 bytes free on /cache (56713216 needed)
[ 29.533880] failed to verify blocks (expected 5168c322a906ed8d87fd05d783cd1b4d4e4f4466, read c392cecc31e0a921af57fe3bbdd16f8c14cd19d7)
[ 29.534009] partition has unexpected contents
[ 29.534098] failed to read blocks for move
[ 29.534178] failed to execute command [move 5168c322a906ed8d87fd05d783cd1b4d4e4f4466 2,87915,87943 28 2,262111,262139]
[ 29.534914] deleting stash 2bdde8504898ccfcd2c59f20bb8c9c25f73bb524
[ 29.541692] Device was remounted R/W 1 times
[ 29.542055] __bionic_open_tzdata: couldn't find any tzdata when looking for GMT!
[ 29.542276] Last remount happened on Thu Jan 1 01:02:58 1970
[ 29.542670] /dev/block/bootdevice/by-name/system image corrupted, attempting to recover...
[ 29.545087] script aborted: E1004: system partition fails to recover
[ 29.751095] E:Error in @/cache/recovery/block.map
[ 29.751138] (Status 7)
[ 29.769828]
[ 29.926499] I:@/cache/recovery/block.map
[ 29.926534] 0
[ 29.926550] time_total: 27
[ 29.926564] retry: 0
[ 29.926578] target_build: 200218
[ 29.926591] source_build: 200217
[ 29.926605] error: 1004
[ 29.926619] cause: 107
[ 29.926632] uncrypt_time: 0
[ 29.926729] Installation aborted.
[ 30.000807] I:Saving locale "en_US"
The error above is generated when I create the Incremental Update with –block parameter, trying without it, I have:
[ 3.446815] I:whole-file signature verified against RSA key 0
[ 3.446926] Update package verification took 1.0 s (result 0).
[ 3.478209] Installing update...
[ 3.542455] sysutil: mmapped 4 ranges
[ 3.577465] Source: qcom/msm8909/msm8909:7.1.2/WPBRv1.0/200217:userdebug/test-keys
[ 3.577627] Target: qcom/msm8909/msm8909:7.1.2/WPBRv1.0/200218:userdebug/test-keys
[ 3.577734] Verifying current system...
[ 3.926947] failed to stat "/system/bin/install-recovery.sh": No such file or directory
[ 3.927064] file "/system/bin/install-recovery.sh" doesn't have any of expected sha1 sums; checking cache
[ 3.927179] failed to stat "/cache/saved.file": No such file or directory
[ 3.927292] failed to load cache file
[ 3.927386] script aborted: E3005: "/system/bin/install-recovery.sh" has unexpected contents.
[ 3.961435] E:Error in @/cache/recovery/block.map
[ 3.961479] (Status 7)
[ 3.994531]
[ 4.139704] I:@/cache/recovery/block.map
[ 4.139738] 0
[ 4.139754] time_total: 1
[ 4.139767] retry: 0
[ 4.139781] target_build: 200218
[ 4.139795] source_build: 200217
[ 4.139808] error: 3005
[ 4.139822] uncrypt_time: 0
[ 4.139920] Installation aborted.
[ 4.211293] I:Saving locale "en_US"
When I apply a Full Update I have success.
I don’t know if I’m making something wrong, if to apply an Incremental Update I cannot add more Apps, for example, it is designed only for changes on source code, but it is not possible to add an App in an Incremental Update.
Kind Regards
