Hi team,
I am using SC20 module for our custom board. We need to test the esim that mounted on it.
- Are there any tools available for SIM test from the shell?/is there any AT commands
2.how can I check the sd card slot working from shell?
Hi team,
Why not use a screen?
thanks for your reply…
The display has not arrived yet, there is a time delay due to technical issues.
So it would be helpful if you suggest an alternative method for testing those stuffs like network sdcard,etc
You can use Vysor to display android screen on your PC.
Thank u for your valuable response.
Now the issue has been solved
