Dear all,
I’m trying to sign an Android Release (Version 7.1.2) with my release keys, but it is not working.
See error below:
signing: MobileUpdateClient.apk (/home/estanislau/work/projects/wellpay/repos/x1_certs/release/platform)
ERROR: No minSdkVersion returned by aapt
More verbose:
running: aapt dump badging /tmp/tmpnEoKHL
Does anybody have an idea? I’m following the steps described on Android Source page (https://source.android.com/devices/tech/ota/sign_builds), my keys don’t have password at this moment, because trying with password I have another error from Java.
Thanks in advance
Can you tell me which command you are using to sign.
Hello Jax.
See the commands execute from build until sign:
Build:
$ source build/envsetup.sh
$ lunch msm8909-userdebug
$ make -j16 dist DIST_DIR=~/dist_output/
Generate keys:
$ subject='/C=BR/ST=Sao Paulo/L=Sao Paulo/O=My Company/OU=R&D/CN=MyCompany/emailAddress=contato@mycompany.com.br'
$ for x in releasekey platform shared media; do ./development/tools/make_key ~/release/$x "$subject" ; done
Signing:
$ ./build/tools/releasetools/sign_target_files_apks -v --default_key_mappings ~/release ~/dist_output/msm8909-target_files.zip ~/dist_output/signed-msm8909-target_files.zip
Output eror when keys are generated without password
ERROR: No minSdkVersion returned by aapt</i>
When I generate keys protecting them with a password, I have another error, see below:
running: openssl pkcs8 -in /home/ubuntu/release/media.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in /home/ubuntu/release/media.pk8 -inform DER -passin pass:
running: openssl pkcs8 -in /home/ubuntu/release/platform.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in /home/ubuntu/release/platform.pk8 -inform DER -passin pass:
running: openssl pkcs8 -in /home/ubuntu/release/releasekey.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in /home/ubuntu/release/releasekey.pk8 -inform DER -passin pass:
running: openssl pkcs8 -in /home/ubuntu/release/shared.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in /home/ubuntu/release/shared.pk8 -inform DER -passin pass:
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/cts-testkey1.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/cts-testkey2.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/keysets/cts-keyset-test-a.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/keysets/cts-keyset-test-b.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/keysets/cts-keyset-test-c.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/keysets/cts-keyset-test-ec-a.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/keyset/…/…/certs/keyset_A.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/keyset/…/…/certs/keyset_B.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/version/…/…/certs/unit_test.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/version/…/…/certs/unit_test_diff.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/version_nosys/…/…/certs/unit_test.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in vendor/unbundled_google/libraries/certs/clockwork.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in vendor/unbundled_google/libraries/certs/clockwork.pk8 -inform DER -passin pass:
Enter password for /home/ubuntu/release/media key>
Enter password for /home/ubuntu/release/platform key>
Enter password for /home/ubuntu/release/releasekey key>
Enter password for /home/ubuntu/release/shared key>
rewriting RECOVERY/RAMDISK/default.prop:
replace: ro.bootimage.build.fingerprint=qcom/msm8909/msm8909:7.1.2/N2G47H/ubuntu01132103:userdebug/test-keys
with: ro.bootimage.build.fingerprint=qcom/msm8909/msm8909:7.1.2/N2G47H/ubuntu01132103:userdebug/release-keys
replace: ro.build.display.id=msm8909-userdebug 7.1.2 N2G47H eng.ubuntu.20200113.210300 test-keys
with: ro.build.display.id=msm8909-userdebug 7.1.2 N2G47H eng.ubuntu.20200113.210300
replace: ro.build.tags=test-keys
with: ro.build.tags=release-keys
replace: ro.build.description=msm8909-userdebug 7.1.2 N2G47H eng.ubuntu.20200113.210300 test-keys
with: ro.build.description=msm8909-userdebug 7.1.2 N2G47H eng.ubuntu.20200113.210300 release-keys
replace: ro.build.fingerprint=qcom/msm8909/msm8909:7.1.2/N2G47H/ubuntu01132103:userdebug/test-keys
with: ro.build.fingerprint=qcom/msm8909/msm8909:7.1.2/N2G47H/ubuntu01132103:userdebug/release-keys
rewriting BOOT/RAMDISK/default.prop:
signing: Telecom.apk (/home/ubuntu/release/platform)
running: aapt dump badging /tmp/tmprvx6Wk
running: java -Xmx2048m -Djava.library.path=out/host/linux-x86/lib64 -jar out/host/linux-x86/framework/signapk.jar --min-sdk-version 25 /home/ubuntu/release/platform.x509.pem /home/ubuntu/release/platform.pk8 /tmp/tmprvx6Wk /tmp/tmpIEEA9j
java.lang.ClassCastException: org.bouncycastle.asn1.DLSequence cannot be cast to org.bouncycastle.asn1.ASN1Integer
at org.bouncycastle.asn1.pkcs.PrivateKeyInfo.(PrivateKeyInfo.java:79)
at org.bouncycastle.asn1.pkcs.PrivateKeyInfo.getInstance(PrivateKeyInfo.java:45)
at com.android.signapk.SignApk.readPrivateKey(SignApk.java:271)
at com.android.signapk.SignApk.main(SignApk.java:1105)
ERROR: signapk.jar failed: return code 1
Hi @jax.zhang
I have same problem, and issue solved like what @Alexandre_Estanislau did.
But the question is "What about removing MobileUpdateClient app? Is there pad effect by removing it?
please give advice.
Hello @jax.zhang
Could you replay my question please?
