have PN7150 NFC controller I am adding the hardware configuration in the device tree. But my device is not registered in i2c bus and device node /dev/pn544 is also not created.
Followed this application note as it is https://www.nxp.com/docs/en/application-note/AN11690.pdf
this is the device tree structure that i have been used:
nfc:pn547@28 {/PN7150 NFC/
compatible = “nxp,pn544”;
reg = <0x28>;
pinctrl-names = “nfc_active”,“nfc_suspend”;
pinctrl-0 = <&nfc_int_active &nfc_disable_active>;
pinctrl-1 = <&nfc_int_suspend &nfc_disable_suspend>;
interrupt-parent = <&msm_gpio>;
interrupts = <14 0x2>;
enable-gpios = <&msm_gpio 92 0x1>;
interrupt-gpios = <&msm_gpio 14 0x1>;
correct me if i’m wrong
I am using the following test application to test the MIFARE cards for nougat using PN7150 NFC chip.
nxpnfc_android_nougat/FactoryTestApp at master · NXPNFCLinux/nxpnfc_android_nougat · GitHub
and it is showing like this :
msm8909:/data # NfcFactoryTestApp
NFC Factory Test Application
Cannot connect to PN71xx NFC controller
255|msm8909:/data #
please help me to solve the problem.
