We are developing a POS machine in Android with SAM card interface. We would like to certify this with EMVCO contactless L1 and L2. Present design including PN7150 (NFC controller with integrated firmware P5DF081 MIFARE SAM AV2 or AV2.6 (SAM card IC) and Androidsupport. Is EMVCO certification is possible with this…? Kindly support our requirement asap.
Regards,
Richu
Hi richucjalpy,
I am internally confirming your problem, and i want to confirm follow with you:
Do you need us to help you with EMVCO certification or do you need us to provide you with some information and then you can do EMVCO certification yourself ?
Thank you
Hi Abby,
It will be better if you could help us with EMVco certification whole process.
Regards,
Richu
Hi richucjalpy,
I have confirmed, because of this is the authentication of terminal payment class, and sorry that we don’t have the resources yet about this!
Thank you
Hi Abby,
Ok, Can you provide any information regarding which NFC IC should use and how to integrate with SC20
Regards,
Richu
Hi richucjalpy,
I remember the NFC you provided before, it is pn7150, this is supported in SC20, and I have gave you the relevant patch, are you having any other problems?
Thank you!
Hi abby,
I have done firmware patch,waiting for customized pcb to arrive.
