SC20-EL Linux Flash and Boot
We can release FTP and Gitlab accounts to customer after customers apply for SDK.
Have you applied SDK for any baseline?
Thanks.
yes we apply for the ftp and SDK file
If yes, the accounts are already released to you
Please help check it,
Thanks.
we need to connect the ftp but the port are not connected . if you have any suggestion to solve these problem .
HI,
This is normal on my side.
You can use other ftp tool in windows first.
Thanks.
we use also windows but cant login to the server . in windows we install the filezilla application to login the server . if we have any suggestion to solve these problem
now we login using filezilla in windows but the server are not connected to our host system . if you have any suggestion to solve the problem . we try connect the ftp server are in passive mode and active mode but does not connect the ftp server . if where any other method connect the server please provide guidance for us.
If ok, you can send your account and password to my email, I can check on my side.
My email is great.zheng@quectel.com
Thanks.
I connect the ftp server and download the all files . thanks for your guidance .
if the SC20E-EM smart module are only compile in the yacto project . if its possible the compilation are in buildroot .
For Linux project, we use yocto.
Thanks.
If we compilation in the buildroot are possible or not in the SC206E-EM smart module.
yocto compilation are take time more compare to the buildroot . so if any possible the compilation are possible in the buildroot.
We can’t use buildroot, they are different frameworks to manage the Linux project, buildroot is mainly used on small project.
Thanks.
Thanks for the support .
I working in the SC20E-EM smart module . we compile the build script and .img file . i should try to upload the firmware using usb cable in ubuntu 18.04 but it does not detect the module . any suggestion to solve these problems
Have you installed adb driver?
no i will install the driver and check the usb are detcted
i am working in the SC206E-EM smart module in ubuntu 18.04 version . i also face the same isuse but i install the adb driver but the module cannot detected the smart module . the module and our host system are connected with type c usb cable . any suggestion for solve the problem . we need to upgrade the firmware in the smart module.
I try upgrade the firmware in windows . I am working in the SC206E-EM smart module . In windows we cannot run the build.bat command after unpacking the SC206 linux tool . the build.bat command only shows the unpacking the linux image file . give me suggestion to solve the problem in our host system.
Please use lsusb command to check.
The issue is mainly related to your pc environment.
I am not clearly know what’s the issue you encounter?
Please provide a image to check.
