I just downloaded this firmware SC20ASAR06A05_BP01.010_Android8.1.0.01.001_update.zip to my evaluation board using QFIL tool and everything is working fine.
The issue is once i build my own images, and i update the board using my custom images. Using QFIL or fastboot produces the same result.
I just got some lines displayed and the board hangs. Please see the attached picture.
I haven’t made any modifications to the images. I just cloned the android repository, copied the quectel sdk and compiled the images.
The output files are:
boot.img
emmc_appsboot.mbn
recovery.img
system.img
userdata.img
I downloaded Android 8 using QFIL with the prebuild package from Quectel.
The board is working fine, using fastboot to update the images with my build ones produces the above issue with the lines on the screen and the board is not able to boot.
Using my images with the QFIL package produces the same issue.
I got some information about the process. Once the board is working using the prebuild Quectel images, i can update: boot.img, system.img, userdata.img and recovery.img with my build files.
Using fastboot all is working as expected. Once i flash the aboot partition using my built emmc_appsboot.mbn i got the lines on the screen and the board is not able to boot. So i can confirm that the issue is on the emmc_appsboot.mbn file.
I think you can contact local fae to open git server from Quectel to get sdk code, as that you can download the latest code with sc20-Android8. Then you can try to complie emmc_appsboot.mbn for a test.
