Running dht22 with mc60
can anyone read data from dht22 with mc60.
thanks a lot to participate..
hey,
To read data from DHT22 with MC60 quectel module, you need to connect the DHT22 sensor to the MC60 module using the GPIO pins. You also need to write a program that can communicate with the sensor and read the temperature and humidity values. One possible way to do this is to use the QuecOpen SDK, which is a software development kit that allows you to create embedded applications for the MC60 module1.
The QuecOpen SDK provides a set of APIs that can be used to access the hardware and software features of the MC60 module, such as GPIO, UART, I2C, SPI, ADC, RTC, GNSS, GPRS, Bluetooth, etc. You can use the Ql_GPIO_Init API to initialize the GPIO pin that is connected to the DHT22 sensor. You can also use the Ql_GPIO_SetLevel API to set the output level of the GPIO pin. You can use the Ql_GPIO_GetLevel API to get the input level of the GPIO pin. [You can use these APIs to implement the communication protocol of the DHT22 sensor]
