RTK not working outside of QGNSS for LG290P in Rover mode
With the QGNSS, my LG290P is working perfectly in Rover mode and GNGGA are received with 4 = Real Time Kinematic (RTK).
However, the same module, antenna not moved, same RTCM parameters, and connected in a RaspberryPi with Node-Red with my javascript code, the GNGGA are received as 2=Differential.
The LG290P return the confirmation that it is in rover mode with $PQTMCFGRCVRMODE,OK,1
The protocols are $PQTMCFGPROT,OK,1,1,00000007,00000007
I received all the NMEA message normally
I’m using an off the shelf node-red widget to get the NTRIP messages (same setting as in QGNSS) and the decoding of RTCM is correct as I can see 1005, 1033, 1077, 1087, 1097… messages decoded correctly
I’m sending the byte arrays of NTRIP to the LG290P. I have tried to send the full arrays and limited arrays of 64 bytes without any difference in results.
This is a typical GNGGA message received: $GNGGA,181613.600,4530.50249723,N,07351.24987288,W,2,34,0.58,28.821,M,-31.186,M,*7E
What step I’m missing ?
Forget about my last post; the buffer array handling between the NTRIP messages and sending the array to the LG290P was in problem. Now I get the R = Real Time Kinematic (RTK).
