RTK LC29HBA with Base Station LG69T
I have tested a LC29HBA module with LG96TAS base station. After conducting tests, we obtained good results.
However, we haven’t been able to locate information regarding the accuracy or deviation of the calculated position in any of the data.
I found in the document:
LC29H&LC79H Series GNSS Protocol Specification
Version: 1.1
that:
GST is not supported for LC29H (BA, CA, DA, EA*).
Could you please assist me in obtaining this information? Since it is a rover that obtained a fix solution, I would like to know how accurate is the obtained position.
Rafael
Hi Rafael,
You can enable PQTMEPE output by sending: $PQTMCFGMSGRATE,W,PQTMEPE,1,2*1D
And saving PQTM configurations by: $PQTMSAVEPAR*5A
I will send you the latest protocol specificaiton via message.
Best regards.
Thanks Raphael.
One more question. I have this current firmware version. Is there a new one?
Best regards
Hi Rafaelvg,
I will send you the latest LC29HBA firmware via message.
Best regards.
Sorry. And can you also send me the latest version of the firmware for such a module? Or at least give me an answer, why the module does not go into rtk mode? Is it possible that the lc29hba module cannot work with rtk everywhere? Please help me.
