hi, we are having problem with RTC alarm. The accuracy of alarm is changing after each callback. The time interval between callbacks is decreasing. here is the code that sets up RTC alarm, when callback occur, recall set alarm with period, default period is 10 second, and our log:
hi,Linh
I can reproduce your issue. Let me confirm with the internal team.
May I ask for your project information? This will help me track the issue more effectively.
it might be related to the alarm clock time. I suggest you can set the alarm clock time longer, such as 30 minutes, and see if the error is the same. Thank you.
