We have a RM5511E-GL running on OpenWRT, and OpenWRT seems to periodically drop our router (set up with an Asus iMesh network) from its routing table whereby all the devices connected to the router will no longer have internet access, yet when we remote in to QuecManager via Tailscale, internet speed tests are just fine (i.e., the data communications between the modem and tower are just fine).
During these disconnects, we noticed in Luci that the router IP would disappear from the Active DHCP Leases list in Luci, but the lease was not necessarily ending (rather the disconnects were triggered by other events - see below). We set static IP on the router, in Luci, and even disabled DHCP and IPv6 in Luci, but none of these changes completely fixed the problem (we seem to get less disconnects when setting static IP in both Luci and the router).
We’ve noticed that the drops occur most frequently (but not always) when making VoIP calls through softphone (MicroSIP and Zoiper) and a VTech hardphone, along with browsing websites like Zillow, RedFine, and Amazon. The disconnects don’t seem to occur when streaming, including that things are fine in 4k.
These disconnects can last anywhere from a few seconds to 10-20 minutes. During this time, the logs show the following repeated:
Thu Aug 21 12:10:35 2025 user.notice QCMAP: 2025-08-21 12:10:35 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:36 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:36 2025 user.notice root: Invalid option
Thu Aug 21 12:10:36 2025 user.notice QCMAP: 2025-08-21 12:10:36 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:37 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:37 2025 user.notice root: Invalid option
Thu Aug 21 12:10:37 2025 user.notice QCMAP: 2025-08-21 12:10:37 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:38 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:38 2025 user.notice root: Invalid option
Thu Aug 21 12:10:38 2025 user.notice QCMAP: 2025-08-21 12:10:38 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:39 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:39 2025 user.notice root: Invalid option
The MAC address is the router.
As a more detailed example, we experienced a disconnect around 08/21/2025 12:04:54 PM, and the router reconnected about 6 minutes later at 08/21/2025 12:11:01 PM. The expanded logs show the following:
Thu Aug 21 12:04:01 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803040_19826
Thu Aug 21 12:04:06 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803045_20437
Thu Aug 21 12:04:11 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803051_21045
Thu Aug 21 12:04:14 2025 user.info LocSvc_LocationIntegrationApiIm[6668]: proc:459] >-- onReceive Rcvd msg id: 99, sockname: locapiservice, payload size: 160
Thu Aug 21 12:04:14 2025 user.warn LocSvc_LocationIntegrationApiIm[6668]: proc:600] <<< unknown message 99
Thu Aug 21 12:04:14 2025 user.info LocSvc_LocationClientApi[6668]: proc:3286] >-- onReceive Rcvd msg id: 99 E_LOCAPI_PINGTEST_MSG_ID, sockname: locapiservice, payload size: 160
Thu Aug 21 12:04:16 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803055_21640
Thu Aug 21 12:04:18 2025 daemon.err at_queue_manager.sh[10069]: cat: can’t open ‘/tmp/at_queue/token’: No such file or directory
Thu Aug 21 12:04:18 2025 daemon.err at_queue_manager.sh[10069]: Failed to parse json data: unexpected end of data
Thu Aug 21 12:04:18 2025 daemon.warn at_queue: Removing expired token from FETCH_DATA_1755803058_21922
Thu Aug 21 12:04:19 2025 daemon.info at_queue: Processing all metrics with token METRICS_1755803059_10070
Thu Aug 21 12:04:21 2025 daemon.debug at_queue: Queue processing paused, token held by METRICS_1755803059_10070
Thu Aug 21 12:04:21 2025 daemon.info at_queue: Metrics processing completed
Thu Aug 21 12:04:26 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803066_23238
Thu Aug 21 12:04:31 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803071_23845
Thu Aug 21 12:04:36 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803076_24451
Thu Aug 21 12:04:41 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803081_25050
Thu Aug 21 12:04:43 2025 daemon.err at_queue_manager.sh[10069]: cat: can’t open ‘/tmp/at_queue/token’: No such file or directory
Thu Aug 21 12:04:43 2025 daemon.err at_queue_manager.sh[10069]: Failed to parse json data: unexpected end of data
Thu Aug 21 12:04:43 2025 daemon.warn at_queue: Removing expired token from
Thu Aug 21 12:04:46 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803086_25662
Thu Aug 21 12:04:48 2025 daemon.err at_queue_manager.sh[10069]: cat: can’t open ‘/tmp/at_queue/token’: No such file or directory
Thu Aug 21 12:04:48 2025 daemon.err at_queue_manager.sh[10069]: Failed to parse json data: unexpected end of data
Thu Aug 21 12:04:48 2025 daemon.warn at_queue: Removing expired token from
Thu Aug 21 12:04:52 2025 daemon.info quecprofiles_daemon: Performing profile check (forced=0)
Thu Aug 21 12:04:52 2025 daemon.info quecprofiles_daemon: Fetching all modem data at once
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Attempting to acquire AT queue token with priority 3
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Successfully acquired token with ID QUECPROFILES_1755803092_16199
Thu Aug 21 12:04:53 2025 daemon.debug at_queue: Queue processing paused, token held by QUECPROFILES_1755803092_16199
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing command: AT+ICCID
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+ICCID (timeout: 5s)
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: AT command executed, status: 0
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing command: AT+CGDCONT?
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+CGDCONT? (timeout: 5s)
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing command: AT+QNWPREFCFG=“mode_pref”
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+QNWPREFCFG=“mode_pref” (timeout: 5s)
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing command: AT+QNWPREFCFG=“lte_band”
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+QNWPREFCFG=“lte_band” (timeout: 5s)
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing command: AT+QNWPREFCFG=“nsa_nr5g_band”
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+QNWPREFCFG=“nsa_nr5g_band” (timeout: 5s)
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing command: AT+QNWPREFCFG=“nr5g_band”
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+QNWPREFCFG=“nr5g_band” (timeout: 5s)
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing command: AT+CGSN
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+CGSN (timeout: 5s)
Thu Aug 21 12:04:53 2025 daemon.err at_queue_manager.sh[10069]: cat: can’t open ‘/tmp/at_queue/token’: No such file or directory
Thu Aug 21 12:04:53 2025 daemon.err at_queue_manager.sh[10069]: Failed to parse json data: unexpected end of data
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Released token QUECPROFILES_1755803092_16199
Thu Aug 21 12:04:53 2025 daemon.warn at_queue: Removing expired token from QUECPROFILES_1755803092_16199
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Extracted ICCID: 89148000010618448245
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Current ICCID: 89148000010618448245
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Looking for profile with ICCID: 89148000010618448245
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Found matching profile: @profile[0]
Thu Aug 21 12:04:53 2025 daemon.debug quecprofiles_daemon: Found valid profile index: @profile[0]
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Found profile: Visible for ICCID: 89148000010618448245
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Profile settings: network_type=LTE, lte_bands=, sa_nr5g_bands=, nsa_nr5g_bands=, apn=vzwinternet, pdp_type=IP, imei=353050682779648, ttl=64
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Profile ‘Visible’ already applied at Tue Aug 19 20:00:17 PDT 2025
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Profile ‘Visible’ is already applied, skipping
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Status updated: success - Profile already applied (from flag) (100%)
Thu Aug 21 12:04:53 2025 daemon.info quecprofiles_daemon: Sleeping for 60 seconds
Thu Aug 21 12:05:14 2025 user.info LocSvc_LocationClientApi[6668]: proc:3286] >-- onReceive Rcvd msg id: 99 E_LOCAPI_PINGTEST_MSG_ID, sockname: locapiservice, payload size: 160
Thu Aug 21 12:05:14 2025 user.info LocSvc_LocationIntegrationApiIm[6668]: proc:459] >-- onReceive Rcvd msg id: 99, sockname: locapiservice, payload size: 160
Thu Aug 21 12:05:14 2025 user.warn LocSvc_LocationIntegrationApiIm[6668]: proc:600] <<< unknown message 99
Thu Aug 21 12:05:16 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:05:16 2025 user.notice root: Invalid option
Thu Aug 21 12:05:16 2025 user.notice QCMAP: 2025-08-21 12:05:16 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:05:17 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:05:17 2025 user.notice root: Invalid option
Thu Aug 21 12:05:17 2025 user.notice QCMAP: 2025-08-21 12:05:17 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:05:21 2025 daemon.info at_queue: Processing all metrics with token METRICS_1755803121_10070
Thu Aug 21 12:05:21 2025 daemon.debug at_queue: Queue processing paused, token held by METRICS_1755803121_10070
Thu Aug 21 12:09:17 2025 daemon.info dnsmasq-dhcp[2723]: DHCPRELEASE(br-lan) 192.168.227.15 cc:28:aa:e7:5e:f0 unknown lease
Thu Aug 21 12:09:17 2025 user.notice QCMAP: 2025-08-21 12:09:17 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:09:17 2025 user.notice QCMAP: 2025-08-21 12:09:17 [lanUtils.sh][util_dhcp_release][2160] interface=br-lan:ip_addr=192.168.227.15:mac_addr=cc:28:aa:e7:5e:f0
Thu Aug 21 12:09:17 2025 user.notice QCMAP: 2025-08-21 12:09:17 [lanUtils.sh][util_dhcp_release][2204] IPPT is not active on profile_idx=0, return
Thu Aug 21 12:09:18 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:09:18 2025 user.notice root: Invalid option
Thu Aug 21 12:09:18 2025 user.notice QCMAP: 2025-08-21 12:09:18 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:32 2025 user.notice QCMAP: 2025-08-21 12:10:32 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:33 2025 daemon.info at_queue: Processing all metrics with token METRICS_1755803433_10070
Thu Aug 21 12:10:33 2025 daemon.debug at_queue: Queue processing paused, token held by METRICS_1755803433_10070
Thu Aug 21 12:10:33 2025 daemon.info dnsmasq-dhcp[2723]: DHCPRELEASE(br-lan) 192.168.227.15 cc:28:aa:e7:5e:f0 unknown lease
Thu Aug 21 12:10:33 2025 user.notice QCMAP: 2025-08-21 12:10:33 [lanUtils.sh][util_dhcp_release][2160] interface=br-lan:ip_addr=192.168.227.15:mac_addr=cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:33 2025 user.notice QCMAP: 2025-08-21 12:10:33 [lanUtils.sh][util_dhcp_release][2204] IPPT is not active on profile_idx=0, return
Thu Aug 21 12:10:33 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:33 2025 user.notice root: Invalid option
Thu Aug 21 12:10:33 2025 user.notice QCMAP: 2025-08-21 12:10:33 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:34 2025 user.notice QCMAP: 2025-08-21 12:10:34 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:35 2025 user.warn kernel: [163205.668323][ T9471] Deleting Client Conntrack IP:192.168.227.15
Thu Aug 21 12:10:35 2025 daemon.info at_queue: Metrics processing completed
Thu Aug 21 12:10:35 2025 daemon.err at_queue_manager.sh[10069]: cat: can’t open ‘/tmp/at_queue/token’: No such file or directory
Thu Aug 21 12:10:35 2025 daemon.err at_queue_manager.sh[10069]: Failed to parse json data: unexpected end of data
Thu Aug 21 12:10:35 2025 daemon.warn at_queue: Removing expired token from
Thu Aug 21 12:10:35 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:35 2025 user.notice root: Invalid option
Thu Aug 21 12:10:45 2025 user.notice QCMAP: 2025-08-21 12:10:45 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:46 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:46 2025 user.notice root: Invalid option
Thu Aug 21 12:10:46 2025 user.notice QCMAP: 2025-08-21 12:10:46 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:48 2025 user.debug LOWI-9.0.1.68[11874]: [LOWINetlinkSocketReceiver] unpackRTMLinkMessage: RTM_NEWLINK - ifname eth0, flags 0x1003 ([UP])
Thu Aug 21 12:10:48 2025 kern.info kernel: [163218.991359][T14949] br-lan: port 1(eth0) entered disabled state
Thu Aug 21 12:10:48 2025 kern.info kernel: [163219.001731][T15196] r8125: eth0: link down
Thu Aug 21 12:10:48 2025 user.warn kernel: [163219.003944][T11187] QCMAP:LINK_DOWN message posted
Thu Aug 21 12:10:48 2025 user.warn kernel: [163219.004030][T11188] QCMAP:LINK_DOWN message posted
Thu Aug 21 12:10:48 2025 daemon.notice ttyd[16411]: rops_handle_POLLIN_netlink: DELADDR
Thu Aug 21 12:10:48 2025 kern.info kernel: [163219.032037][T29850] r8125_ioss 0000:01:00.0-ioss: ioss:cfg:(eth0) Unmapped RX-1 event 0x00000000810018a0 → 0x0000000003e188a0
Thu Aug 21 12:10:48 2025 user.warn kernel: [163219.034338][T11204] Deleting Client Conntrack IP:192.168.227.15
Thu Aug 21 12:10:48 2025 kern.info kernel: [163219.046248][T29850] r8125_ioss 0000:01:00.0-ioss: ioss:cfg:(eth0) Unmapped TX-1 event 0x0000000081002d20 → 0x0000000003e18d20
Thu Aug 21 12:10:48 2025 user.notice root: tethering.sh:2666:Invalid option
Thu Aug 21 12:10:48 2025 daemon.info dnsmasq-dhcp[2723]: DHCPRELEASE(br-lan) 192.168.227.15 cc:28:aa:e7:5e:f0 unknown lease
Thu Aug 21 12:10:48 2025 kern.warn kernel: [163219.081937][ T3220] __ipa_add_flt_get_ep_idx: 1 callbacks suppressed
Thu Aug 21 12:10:48 2025 kern.err kernel: [163219.081949][ T3220] ipa __ipa_add_flt_get_ep_idx:1248 ep not connected ep_idx=8
Thu Aug 21 12:10:48 2025 user.notice QCMAP: 2025-08-21 12:10:48 [tethering.sh][639][delete_macsec_from_bridge] macsec not enabled
Thu Aug 21 12:10:48 2025 user.notice QCMAP: 2025-08-21 12:10:48 [lanUtils.sh][util_dhcp_release][2160] interface=br-lan:ip_addr=192.168.227.15:mac_addr=cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:48 2025 user.notice QCMAP: 2025-08-21 12:10:48 [lanUtils.sh][util_dhcp_release][2204] IPPT is not active on profile_idx=0, return
Thu Aug 21 12:10:48 2025 kern.info kernel: [163219.342637][T29850] eth0: 0xffffffc009cb0000, ca:59:6a:74:2f:8c, IRQ 38
Thu Aug 21 12:10:49 2025 user.debug LOWI-9.0.1.68[11874]: [LOWINetlinkSocketReceiver] unpackRTMLinkMessage: RTM_NEWLINK - ifname br-lan, flags 0x1003 ([UP])
Thu Aug 21 12:10:50 2025 user.warn kernel: [163221.109212][T11435] QCMAP:LINK_DOWN Processed
Thu Aug 21 12:10:52 2025 kern.info kernel: [163223.276008][T15196] r8125: eth0: link up
Thu Aug 21 12:10:52 2025 kern.info kernel: [163223.280668][T15196] br-lan: port 1(eth0) entered blocking state
Thu Aug 21 12:10:52 2025 kern.info kernel: [163223.286908][T15196] br-lan: port 1(eth0) entered forwarding state
Thu Aug 21 12:10:52 2025 user.debug LOWI-9.0.1.68[11874]: [LOWINetlinkSocketReceiver] unpackRTMLinkMessage: RTM_NEWLINK - ifname eth0, flags 0x11043 ([UP][RUNNING])
Thu Aug 21 12:10:52 2025 user.warn kernel: [163223.297564][T11596] QCMAP:ETH mode
Thu Aug 21 12:10:52 2025 user.warn kernel: [163223.297729][T11597] QCMAP:ETH mode
Thu Aug 21 12:10:52 2025 user.debug LOWI-9.0.1.68[11874]: [LOWINetlinkSocketReceiver] unpackRTMLinkMessage: RTM_NEWLINK - ifname br-lan, flags 0x11043 ([UP][RUNNING])
Thu Aug 21 12:10:52 2025 user.warn kernel: [163223.306587][T11601] QCMAP:LINK_UP message posted
Thu Aug 21 12:10:52 2025 kern.info kernel: [163223.312801][T11219] r8125_ioss 0000:01:00.0-ioss: ioss:cfg:(eth0) Voted for IPA bandwidth of 2500 Mbps
Thu Aug 21 12:10:52 2025 user.warn kernel: [163223.314894][T11605] QCMAP:LINK_UP message posted
Thu Aug 21 12:10:52 2025 kern.info kernel: [163223.325456][T11219] r8125_ioss 0000:01:00.0-ioss: ioss:cfg:(eth0) Mapped RX-1 event 0x00000000810018a0 → 0x0000000003e188a0
Thu Aug 21 12:10:52 2025 kern.info kernel: [163223.343799][T11219] r8125_ioss 0000:01:00.0-ioss: ioss:cfg:(eth0) Mapped TX-1 event 0x0000000081002d20 → 0x0000000003e18d20
Thu Aug 21 12:10:52 2025 user.notice root: tethering.sh:2666:Invalid option
Thu Aug 21 12:10:52 2025 user.notice QCMAP: 2025-08-21 12:10:52 [tethering.sh][460][start_macsec] macsec not enabled
Thu Aug 21 12:10:52 2025 user.notice QCMAP: 2025-08-21 12:10:52 [lanUtils.sh][util_inc_dec_restart_link_count][2045] Enter : increment=0 :device_type=4
Thu Aug 21 12:10:52 2025 user.notice QCMAP: 2025-08-21 12:10:52 [lanUtils.sh][util_get_restart_link_count][2023] Enter function
Thu Aug 21 12:10:53 2025 user.notice QCMAP: 2025-08-21 12:10:53 [lanUtils.sh][util_inc_dec_restart_link_count][2049] restart_link_count=0
Thu Aug 21 12:10:53 2025 user.notice QCMAP: 2025-08-21 12:10:53 [lanUtils.sh][util_inc_dec_restart_link_count][2055] Invalid restart_link_count: restart_link_count=0
Thu Aug 21 12:10:54 2025 kern.warn kernel: [163225.298778][ T3220] __ipa3_del_rt_rule: 2 callbacks suppressed
Thu Aug 21 12:10:54 2025 kern.err kernel: [163225.298789][ T3220] ipa __ipa3_del_rt_rule:1823 bad params
Thu Aug 21 12:10:54 2025 kern.warn kernel: [163225.310953][ T3220] ipa3_del_rt_rule: 5 callbacks suppressed
Thu Aug 21 12:10:54 2025 kern.err kernel: [163225.310962][ T3220] ipa ipa3_del_rt_rule:1906 failed to del rt rule 1
Thu Aug 21 12:10:54 2025 kern.warn kernel: [163225.324188][ T3220] __ipa3_del_rt_rule: 2 callbacks suppressed
Thu Aug 21 12:10:54 2025 kern.err kernel: [163225.324198][ T3220] ipa __ipa3_del_rt_rule:1818 lookup failed
Thu Aug 21 12:10:54 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:54 2025 user.notice radio: :QCMAP_ConnectionManager: DecRestartLinkCount: Deleted successfully
Thu Aug 21 12:10:54 2025 user.warn kernel: [163225.377466][T11850] QCMAP:LINK_UP Processed
Thu Aug 21 12:10:55 2025 user.notice root: ippt.sh:2666:Invalid option
Thu Aug 21 12:10:55 2025 user.notice root: Invalid option
Thu Aug 21 12:10:55 2025 user.notice QCMAP: 2025-08-21 12:10:55 [ippt.sh][ql_update_ippt_dhcp_host][2204] vlan:0; MAC: cc:28:aa:e7:5e:f0
Thu Aug 21 12:10:55 2025 user.warn kernel: [163225.471838][T11926] QCMAP:bringup v6
Thu Aug 21 12:10:56 2025 user.warn kernel: [163226.503350][T12072] QCMAP:bringup v6
Thu Aug 21 12:10:56 2025 user.warn kernel: [163226.565922][T12079] QCMAP:bringup v6
Thu Aug 21 12:10:56 2025 user.warn kernel: [163226.613942][T12087] QCMAP:bringup v6
Thu Aug 21 12:10:56 2025 user.warn kernel: [163226.656424][T12093] QCMAP:bringup v6
Thu Aug 21 12:10:56 2025 daemon.info quecprofiles_daemon: Performing profile check (forced=0)
Thu Aug 21 12:10:56 2025 daemon.info quecprofiles_daemon: Fetching all modem data at once
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Attempting to acquire AT queue token with priority 3
Thu Aug 21 12:10:56 2025 daemon.debug at_queue: Queue processing paused, token held by QUECPROFILES_1755803456_16199
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Successfully acquired token with ID QUECPROFILES_1755803456_16199
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing command: AT+ICCID
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+ICCID (timeout: 5s)
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: AT command executed, status: 0
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing command: AT+CGDCONT?
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+CGDCONT? (timeout: 5s)
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing command: AT+QNWPREFCFG=“mode_pref”
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+QNWPREFCFG=“mode_pref” (timeout: 5s)
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing command: AT+QNWPREFCFG=“lte_band”
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+QNWPREFCFG=“lte_band” (timeout: 5s)
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing command: AT+QNWPREFCFG=“nsa_nr5g_band”
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+QNWPREFCFG=“nsa_nr5g_band” (timeout: 5s)
Thu Aug 21 12:10:56 2025 daemon.debug quecprofiles_daemon: Executing command: AT+QNWPREFCFG=“nr5g_band”
Thu Aug 21 12:10:57 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+QNWPREFCFG=“nr5g_band” (timeout: 5s)
Thu Aug 21 12:10:57 2025 daemon.debug quecprofiles_daemon: AT command executed, status: 0
Thu Aug 21 12:10:57 2025 daemon.debug quecprofiles_daemon: Executing command: AT+CGSN
Thu Aug 21 12:10:57 2025 daemon.debug quecprofiles_daemon: Executing AT command: AT+CGSN (timeout: 5s)
Thu Aug 21 12:10:57 2025 daemon.debug quecprofiles_daemon: Released token QUECPROFILES_1755803456_16199
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Extracted ICCID: 89148000010618448245
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Current ICCID: 89148000010618448245
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Looking for profile with ICCID: 89148000010618448245
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Found matching profile: @profile[0]
Thu Aug 21 12:10:57 2025 daemon.debug quecprofiles_daemon: Found valid profile index: @profile[0]
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Found profile: Visible for ICCID: 89148000010618448245
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Profile settings: network_type=LTE, lte_bands=, sa_nr5g_bands=, nsa_nr5g_bands=, apn=vzwinternet, pdp_type=IP, imei=353050682779648, ttl=64
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Profile ‘Visible’ already applied at Tue Aug 19 20:00:17 PDT 2025
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Profile ‘Visible’ is already applied, skipping
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Status updated: success - Profile already applied (from flag) (100%)
Thu Aug 21 12:10:57 2025 daemon.info quecprofiles_daemon: Sleeping for 60 seconds
Thu Aug 21 12:10:57 2025 user.warn kernel: [163227.690301][T12398] QCMAP:bringup v6
Thu Aug 21 12:10:59 2025 user.warn kernel: [163229.726125][T12577] QCMAP:bringup v6
Thu Aug 21 12:11:01 2025 user.debug LOWI-9.0.1.68[11874]: [LOWINetlinkSocketReceiver] unpackRTMLinkMessage: RTM_NEWLINK - ifname eth0, flags 0x11043 ([UP][RUNNING])
Thu Aug 21 12:11:03 2025 user.warn kernel: [163233.762509][T12953] QCMAP:bringup v6
Thu Aug 21 12:11:09 2025 daemon.debug at_queue: Cleaned up old tracking files
Thu Aug 21 12:11:09 2025 daemon.info at_queue: Cleanup: Removed files older than 1 hour
Thu Aug 21 12:11:11 2025 user.warn kernel: [163241.804383][T13660] QCMAP:bringup v6
Thu Aug 21 12:11:14 2025 user.info LocSvc_LocationIntegrationApiIm[6668]: proc:459] >-- onReceive Rcvd msg id: 99, sockname: locapiservice, payload size: 160
Thu Aug 21 12:11:14 2025 user.warn LocSvc_LocationIntegrationApiIm[6668]: proc:600] <<< unknown message 99
Thu Aug 21 12:11:14 2025 user.info LocSvc_LocationClientApi[6668]: proc:3286] >-- onReceive Rcvd msg id: 99 E_LOCAPI_PINGTEST_MSG_ID, sockname: locapiservice, payload size: 160
Thu Aug 21 12:11:27 2025 user.warn kernel: [163257.838948][T15029] QCMAP:bringup v6
Thu Aug 21 12:11:30 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803490_15324
Thu Aug 21 12:11:31 2025 daemon.err at_queue_manager.sh[10069]: cat: can’t open ‘/tmp/at_queue/token’: No such file or directory
Thu Aug 21 12:11:31 2025 daemon.err at_queue_manager.sh[10069]: Failed to parse json data: unexpected end of data
Thu Aug 21 12:11:31 2025 daemon.warn at_queue: Removing expired token from FETCH_DATA_1755803490_15324
Thu Aug 21 12:11:35 2025 daemon.info at_queue: Processing all metrics with token METRICS_1755803495_10070
Thu Aug 21 12:11:35 2025 daemon.debug at_queue: Queue processing paused, token held by METRICS_1755803495_10070
Thu Aug 21 12:11:35 2025 user.info : luci: accepted login on /admin/status/logs for root from 192.168.227.15
Thu Aug 21 12:11:36 2025 daemon.err at_queue_manager.sh[10069]: cat: can’t open ‘/tmp/at_queue/token’: No such file or directory
Thu Aug 21 12:11:36 2025 daemon.err at_queue_manager.sh[10069]: Failed to parse json data: unexpected end of data
Thu Aug 21 12:11:36 2025 daemon.warn at_queue: Removing expired token from FETCH_DATA_1755803495_16026
Thu Aug 21 12:11:37 2025 daemon.info at_queue: Metrics processing completed
Thu Aug 21 12:11:40 2025 daemon.debug at_queue: Queue processing paused, token held by FETCH_DATA_1755803500_16724
I believe the firmware we are running is below:
Powered by LuCI luci/luci/openwrt-22.03 branch (git-23.093.57104-ce20b4a) / RM551EGL00AAR01A04M8G_2025_8_4_iamromulan_full r20134-5f15225c1e
Any help would be GREATLY appreciated.
