RM551 lost 5G with firmare RM551EGL00AAR02A02M8G
Hi @silvia,
I’ve upgraded my RM551 module from firmware R01 to R02, and it losts the 5G aggregation in NSA:
Radio 0: Compile: Nov  5 2025/10:15:44, Release: Oct 16 2025/06:00:00, Chipset: pinnacle
Radio 0: Build ID: RM551EGL00AAR02A02M8G
Radio 0: Log Config: Retrieve ID ranges: 1: 2119, 4: 4087, 5: 4087, 7: 2910, 10: 914, 11: 2559, 13: 519,
Radio 0: Extended message range: 0-142, 500-506, 1000-1007, 2000-2008, 3000-3014, 4000-4010, 4500-4584, 4600-4616, 5000-5037, 5500-5517, 6000-6082, 6500-6521, 7000-7003, 7100-7111, 7200-7201, 8000-8000, 8500-8532, 9000-9008, 9500-9521, 10200-10210, 10251-10255, 10300-10300, 10350-10377, 10400-10416, 10500-10505, 10600-10620, 10801-10836, 11057-11079, 49152-49251,
2025-11-21 21:40:48,085 scat.qualcommparser (prepare_diag) INFO: Starting diag
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.12, Measured RSSI -71.38, Measured RSRQ -15.06
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.19, Measured RSSI -72.69, Measured RSRQ -13.75
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.00, Measured RSSI -72.56, Measured RSRQ -13.69
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.06, Measured RSSI -74.56, Measured RSRQ -11.75
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.25, Measured RSSI -71.31, Measured RSRQ -15.19
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.00, Measured RSSI -74.69, Measured RSRQ -11.56
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -104.69, Measured RSSI -74.06, Measured RSRQ -11.88
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.19, Measured RSSI -72.75, Measured RSRQ -13.69
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.12, Measured RSSI -74.38, Measured RSRQ -12.00
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.12, Measured RSSI -73.88, Measured RSRQ -12.50
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.00, Measured RSSI -75.25, Measured RSRQ -11.00
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.31, Measured RSSI -75.75, Measured RSRQ -10.81
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.25, Measured RSSI -75.81, Measured RSRQ -10.69
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.19, Measured RSSI -75.31, Measured RSRQ -11.12
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.62, Measured RSSI -75.31, Measured RSRQ -11.50
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.88, Measured RSSI -73.25, Measured RSRQ -13.94
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.38, Measured RSSI -73.75, Measured RSRQ -12.94
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.25, Measured RSSI -75.50, Measured RSRQ -11.00
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.69, Measured RSSI -74.94, Measured RSRQ -12.00
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.44, Measured RSSI -75.00, Measured RSRQ -11.75
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -105.88, Measured RSSI -76.25, Measured RSRQ -10.88
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.62, Measured RSSI -76.00, Measured RSRQ -10.75
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.50, Measured RSSI -74.75, Measured RSRQ -11.81
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.44, Measured RSSI -75.75, Measured RSRQ -11.25
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.06, Measured RSSI -75.00, Measured RSRQ -12.06
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.25, Measured RSSI -75.38, Measured RSRQ -11.31
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.25, Measured RSSI -75.88, Measured RSRQ -10.69
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.31, Measured RSSI -74.88, Measured RSRQ -11.81
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.94, Measured RSSI -76.06, Measured RSRQ -11.19
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -106.62, Measured RSSI -73.50, Measured RSRQ -12.56
Radio 0: NR RRC OTA Packet: NR-ARFCN 4294967295, PCI 65535, Type: nr-RadioBearerConfig
Radio 0: NR RRC OTA Packet: Body: 14092857afc26c10
Radio 0: 5GMM State: 1/2/1, PLMN: 222/ 10, TAC:      0, GUTI: ffffffffffffffffffffffff
Radio 0: LTE ML1 Cell Info: EARFCN 6200, PCI 449, Bandwidth 10 MHz, Num antennas 1
Radio 0: LTE MIB Info: EARFCN 6200, SFN  355, Bandwidth 10 MHz, TX antennas 2
Radio 0: LTE SCell: EARFCN 6200, PCI 449, Measured RSRP -94.81, Measured RSSI -63.81, Measured RSRQ -14.00
Radio 0: LTE RRC SCell Info: EARFCN 6200/24200, Band 20, Bandwidth 10/10 MHz, PCI 449, xTAC/xCID 77c8/4d56008, MCC 222, MNC 88
Radio 0: LTE SCell: EARFCN 6200, PCI 449, Measured RSRP -95.50, Measured RSSI -64.31, Measured RSRQ -14.19
Radio 0: LTE MIB Info: EARFCN 6200, SFN  384, Bandwidth 10 MHz, TX antennas 2
Radio 0: LTE SCell: EARFCN 6200, PCI 449, Measured RSRP -95.31, Measured RSSI -64.56, Measured RSRQ -13.81
Radio 0: LTE ML1 Cell Info: EARFCN 525, PCI 225, Bandwidth 15 MHz, Num antennas 1
Radio 0: LTE MIB Info: EARFCN 525, SFN  448, Bandwidth 15 MHz, TX antennas 2
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.38, Measured RSSI -73.69, Measured RSRQ -10.94
Radio 0: LTE RRC SCell Info: EARFCN 525/18525, Band 1, Bandwidth 15/15 MHz, PCI 225, xTAC/xCID 80eb/10f752a, MCC 222, MNC 10
Radio 0: NR RRC OTA Packet: Body: 14092817afc26c10
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -102.75, Measured RSSI -73.19, Measured RSRQ -10.81
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.00, Measured RSSI -72.94, Measured RSRQ -11.31
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -102.56, Measured RSSI -72.94, Measured RSRQ -10.81
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.00, Measured RSSI -73.25, Measured RSRQ -11.00
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.19, Measured RSSI -73.00, Measured RSRQ -11.50
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -104.06, Measured RSSI -73.69, Measured RSRQ -11.12
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -104.12, Measured RSSI -73.50, Measured RSRQ -11.62
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -104.00, Measured RSSI -74.38, Measured RSRQ -10.69
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.56, Measured RSSI -74.12, Measured RSRQ -10.69
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -104.00, Measured RSSI -73.31, Measured RSRQ -11.88
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.62, Measured RSSI -72.88, Measured RSRQ -12.00
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.69, Measured RSSI -70.62, Measured RSRQ -14.38
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.56, Measured RSSI -72.88, Measured RSRQ -11.94
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.81, Measured RSSI -72.56, Measured RSRQ -12.50
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.50, Measured RSSI -73.19, Measured RSRQ -11.56
Radio 0: LTE SCell: EARFCN 525, PCI 225, Measured RSRP -103.62, Measured RSSI -73.38, Measured RSRQ -11.50
^C2025-11-21 21:41:23,330 scat.qualcommparser (stop_diag) INFO: Stopping diag
If I’m forcing SA mode, it seems to see 5G BTS, but we don’t have SA there:
Radio 0: 5GMM State: 3/4/1, PLMN: 222/ 10, TAC:      0, GUTI: ffffffffffffffffffffffff
Radio 0: NR ML1 Meas Packet: Layers 1, ssb_periocity 0
Radio 0: Layer 0: NR-ARFCN 643296, SCell PCI 65535/SSB 15, RSRP 0.00/0.00/0.00/0.00, RX beam NA/NA, Num Cells: 2 (S: 255)
Radio 0: └── Cell 0: PCI  790, PBCH SFN 288, RSRP: -96.99, RSRQ: -11.51, Num Beams: 1
Radio 0:     └── Beam 0: SSB[1] Beam ID 0/0, RSRP -96.99/-104.29, RSRQ -11.51/-12.16, Filtered RSRP/RSRQ (Nr2Nr) -96.99/-11.51, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 1: PCI  616, PBCH SFN 288, RSRP: -115.96, RSRQ: -18.06, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -115.96/-116.23, RSRQ -19.77/-18.06, Filtered RSRP/RSRQ (Nr2Nr) -115.96/-18.06, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: NR MIB: NR-ARFCN 643296, PCI  790, SFN: 0, SCS: 30 kHz
Radio 0: NR RRC OTA Packet: NR-ARFCN 643296, PCI 790, NR CGI:   0-  0-        0
Radio 0: NR MIB: NR-ARFCN 643296, PCI  616, SFN: 0, SCS: 30 kHz
Radio 0: NR RRC OTA Packet: NR-ARFCN 643296, PCI 616, NR CGI:   0-  0-        0
Radio 0: Layer 0: NR-ARFCN 516030, SCell PCI 65535/SSB 15, RSRP 0.00/0.00/0.00/0.00, RX beam NA/NA, Num Cells: 1 (S: 255)
Radio 0: └── Cell 0: PCI  641, PBCH SFN 302, RSRP: -114.88, RSRQ: -14.63, Num Beams: 1
Radio 0:     └── Beam 0: SSB[5] Beam ID 0/0, RSRP -121.63/-114.88, RSRQ -23.02/-14.63, Filtered RSRP/RSRQ (Nr2Nr) -114.88/-14.63, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 0: PCI  641, PBCH SFN 304, RSRP: -113.23, RSRQ: -13.19, Num Beams: 1
Radio 0:     └── Beam 0: SSB[5] Beam ID 0/0, RSRP -116.76/-113.23, RSRQ -18.59/-13.19, Filtered RSRP/RSRQ (Nr2Nr) -113.23/-13.19, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: NR MIB: NR-ARFCN 516030, PCI  641, SFN: 0, SCS: 30 kHz
Radio 0: NR RRC OTA Packet: NR-ARFCN 516030, PCI 641, NR CGI:   0-  0-        0
Radio 0: Layer 0: NR-ARFCN 638016, SCell PCI 65535/SSB 15, RSRP 0.00/0.00/0.00/0.00, RX beam NA/NA, Num Cells: 1 (S: 255)
Radio 0: └── Cell 0: PCI  137, PBCH SFN 322, RSRP: -119.77, RSRQ: -19.97, Num Beams: 1
Radio 0:     └── Beam 0: SSB[6] Beam ID 0/0, RSRP -119.77/-121.25, RSRQ -19.97/-22.16, Filtered RSRP/RSRQ (Nr2Nr) -119.77/-19.97, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: NR MIB: NR-ARFCN 638016, PCI  137, SFN: 0, SCS: 30 kHz
Radio 0: NR RRC OTA Packet: NR-ARFCN 638016, PCI 137, NR CGI:   0-  0-        0
Radio 0: Layer 0: NR-ARFCN 368890, SCell PCI 65535/SSB 15, RSRP 0.00/0.00/0.00/0.00, RX beam NA/NA, Num Cells: 1 (S: 255)
Radio 0: └── Cell 0: PCI  764, PBCH SFN 346, RSRP: -105.38, RSRQ: -14.00, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -105.38/-107.67, RSRQ -14.00/-14.88, Filtered RSRP/RSRQ (Nr2Nr) -105.38/-14.00, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: NR MIB: NR-ARFCN 368890, PCI  764, SFN: 0, SCS: 15 kHz
Radio 0: NR RRC OTA Packet: NR-ARFCN 368890, PCI 764, NR CGI:   0-  0-        0
Radio 0: NR ML1 Meas Packet: Layers 1, ssb_periocity 20
Radio 0: Layer 0: NR-ARFCN 368890, SCell PCI  764/SSB 3, RSRP 0.00/0.00/0.00/0.00, RX beam NA/NA, Num Cells: 2 (S: 0)
Radio 0: └── Cell 0: PCI  764, PBCH SFN 364, RSRP: -105.26, RSRQ: -13.52, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -105.16/-107.44, RSRQ -12.34/-13.47, Filtered RSRP/RSRQ (Nr2Nr) -105.26/-13.52, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 1: PCI  642, PBCH SFN 352, RSRP: -116.40, RSRQ: -19.13, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -156.00/-112.44, RSRQ -43.00/-18.77, Filtered RSRP/RSRQ (Nr2Nr) -116.40/-19.13, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 0: PCI  764, PBCH SFN 380, RSRP: -105.05, RSRQ: -13.16, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -104.23/-105.96, RSRQ -12.17/-12.62, Filtered RSRP/RSRQ (Nr2Nr) -105.05/-13.16, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 1: PCI  642, PBCH SFN 352, RSRP: -115.38, RSRQ: -18.74, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -156.00/-111.61, RSRQ -43.00/-18.03, Filtered RSRP/RSRQ (Nr2Nr) -115.38/-18.74, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 0: PCI  764, PBCH SFN 396, RSRP: -104.93, RSRQ: -12.88, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -105.03/-107.33, RSRQ -12.41/-13.22, Filtered RSRP/RSRQ (Nr2Nr) -104.93/-12.88, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 1: PCI  642, PBCH SFN 352, RSRP: -114.88, RSRQ: -18.70, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -115.37/-112.79, RSRQ -22.98/-18.93, Filtered RSRP/RSRQ (Nr2Nr) -114.88/-18.70, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 0: PCI  764, PBCH SFN 412, RSRP: -104.90, RSRQ: -12.71, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -104.75/-107.42, RSRQ -12.05/-13.41, Filtered RSRP/RSRQ (Nr2Nr) -104.90/-12.71, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 1: PCI  642, PBCH SFN 352, RSRP: -115.35, RSRQ: -19.02, Num Beams: 1
Radio 0:     └── Beam 0: SSB[3] Beam ID 0/0, RSRP -156.00/-114.59, RSRQ -43.00/-20.89, Filtered RSRP/RSRQ (Nr2Nr) -115.35/-19.02, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 0: PCI  641, PBCH SFN 440, RSRP: -113.67, RSRQ: -13.62, Num Beams: 1
Radio 0:     └── Beam 0: SSB[5] Beam ID 0/0, RSRP -116.85/-113.67, RSRQ -18.52/-13.62, Filtered RSRP/RSRQ (Nr2Nr) -113.67/-13.62, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Radio 0: └── Cell 0: PCI  641, PBCH SFN 444, RSRP: -113.05, RSRQ: -13.50, Num Beams: 1
Radio 0:     └── Beam 0: SSB[5] Beam ID 0/0, RSRP -115.45/-113.05, RSRQ -18.47/-13.50, Filtered RSRP/RSRQ (Nr2Nr) -113.05/-13.50, Filtered RSRP/RSRQ (L2Nr) 0.00/0.00
Any ideas? I’ve already tried factory reset and full reflash, but nothing to do. Only with R01 firmware it uses 5G NSA band
Thanks in advance!
Just an update.. 5G doesn’t seem to work only on TIM\Vodafone Italy, while is working on Wind3 Italy.
Do you have put any restrict on carrier?
Dear @stich86
We don’t have restrict on carrier.
As mentioned before, it is not recommended to upgrade from R01 to R02.
Why not?
And why R02 works with Wind3 but not with Tim/Vodafone?
There should be some sort of restrictions
I would try swapping the mbn files of interest between the R01 and R02 as a test or testing with Row commercial profile
Dear @stich86
We are not sure whether it has some unexpected behavior after upgrade.
From software, we didn’t add any restrictions.
There should be something that prevent the model to send NR5G bearer configuration.
Is it possible to run a debug on DIAG so you can understand why?
Dear @stich86
If you can capture log via USB port, it will help us to check.
Can you share me the procedure via email? Thanks
@silvia can you send me latest firmware for RM551E-GL?
I have currently RM551EGL00AAR02A02M8G
Also some instruction how to flash using openwrt router root access.
Can I get latest firmware for RM551E-GL: RM551EGL00AAR02A02M8G ?
Dear @emarudee
RM551EGL00AAR02A02M8G is the latest one.
