KG5PAX
July 26, 2024, 11:08pm
1
Hello! Can I please get the latest firmware and Windows and Linux drivers for the RM530N-GL?
For Linux (FreeBSD), I have not been able to query the pcie device at /dev/cuau2 and is not one of the tty devices available, so I think the driver needs to be installed.
Thank you!
For Linux,
Please check whether the USB device is recognized first.
Please check
lsusb
lsusb -t
cat /sys/kernel/debug/usb/devices
Actually for the Linux driver, it is the Linux kernel native driver, what you need to do is just add the USB VID and PID into the option_ids.
KG5PAX
July 30, 2024, 9:58pm
4
Thank you for your reply, Bean.
Here is the output of lsusb
Bus /dev/usb Device /dev/ugen0.3: ID 2c7c:0801 Quectel Wireless Solutions Co., Ltd.
However, I am not able to AT to this device at /dev/cuau2* or /dev/tty*
Are these the correct VID and PID for my modem? Where is VID and PID declared so I can change them if necessary?
OK. It is recoginized.
You can try
sudo modprobe option
echo 2C7C 0801 FF | sudo tee /sys/bus/usb-serial/drivers/option1/new_id
And then you might be able to see the ttyUSBx.
