Since 12 June 2024, Digikey says RM510Q-GL modem is end-of-life: https://www.digikey.com/en/products/detail/quectel/rm510qglha-m20-sgasa/13278308
Can I buy IF cables for RM530N-GL to work in 5GMMWAVEEVB-KIT with RA510T antenna modules?
Dear @heedev
RM530N can work with 5GMMWAVEEVB-KIT.
For antenna, it is recommand to use RM530N-GL with QTM545 (mmWave antenna module).
Where can I buy cables to connect RM530N-GL mmWave connectors to QTM545 antenna modules?
Yes, and all pieces to use QTM545 with RM530N-GL.
I have 5GMMWAVEEVB-KIT (https://www.digikey.com/en/products/detail/quectel/5GMMWAVEEVB-KIT/13278137).
What else do I need to purchase to use RM530-GL with 5GMMWAVEEVB-KIT? (QTM545 modules; QTM545 N0, N1, N2, N3 brackets; cables, RM530N-GL?)
Thank you!
Dear @heedev
Actually, the EVB kits for RM530N-GL has the brackets.
