RM530N-GL AT Commond isssue
I have used RM530N-GL module and firmware virson is RM530NGLAAR05A01M4G when i run AT commond
AT+QSCAN=3,1 in first time give output then run next time got ok
[2025-12-17 11:11:15:922_S:] AT+QSCAN=3,1
[2025-12-17 11:11:15:979_R:] AT+QSCAN=3,1
[2025-12-17 11:12:02:544_R:] +QSCAN: “LTE”,405,872,2525,200,-96,-12,32,116,354032,2A,50,5
[2025-12-17 11:12:02:544_R:] +QSCAN: “LTE”,405,872,1251,278,-100,-13,28,115,354025,2A,50,3
[2025-12-17 11:12:02:544_R:] +QSCAN: “LTE”,405,872,38750,49,-95,-9,33,113,6DE11,2A,100,40
[2025-12-17 11:12:02:544_R:] +QSCAN: “LTE”,405,872,38948,59,-95,-14,33,114,6DE14,2A,100,40
[2025-12-17 11:12:02:544_R:] +QSCAN: “LTE”,404,10,315,23,-104,-12,20,22,E717135,88D,75,1
[2025-12-17 11:12:02:544_R:] +QSCAN: “LTE”,404,10,39294,23,-105,-17,19,14,9DD9117,88D,50,40
[2025-12-17 11:12:02:544_R:] +QSCAN: “LTE”,404,10,1346,23,-99,-10,25,25,E717103,88D,25,3
[2025-12-17 11:12:02:544_R:] +QSCAN: “LTE”,404,11,1421,226,-107,-14,17,18,7066216,CD67,50,3
[2025-12-17 11:12:02:544_R:] +QSCAN: “NR5G”,405,872,156510,85,-98,-17,23,0,105280011,2A,52,28,13,6,-
[2025-12-17 11:12:02:544_R:] +QSCAN: “NR5G”,404,10,629952,2,-119,-17,-8,1,3586E7538,88D,273,78,248,12,-
[2025-12-17 11:12:02:544_R:] +QSCAN: “NR5G”,405,872,634080,57,-99,-11,22,1,106E28001,2A,273,78,36,2,-
[2025-12-17 11:12:02:544_R:] +QSCAN: “NR5G”,404,11,624096,85,-,-,-,1,22327C0B5,-,133,78,36,4,-
[2025-12-17 11:12:02:544_R:] OK
[2025-12-17 11:12:21:283_S:] AT+QSCAN=3,1
[2025-12-17 11:12:21:349_R:] AT+QSCAN=3,1
[2025-12-17 11:12:22:420_R:] OK
[2025-12-17 11:12:24:147_S:] AT+QSCAN=3,1
[2025-12-17 11:12:24:205_R:] AT+QSCAN=3,1
[2025-12-17 11:12:25:278_R:] OK
[2025-12-17 11:12:27:346_S:] AT+QSCAN=3,1
[2025-12-17 11:12:27:407_R:] AT+QSCAN=3,1AT+QSCAN=3,1
[2025-12-17 11:12:28:487_R:] OK
[2025-12-17 11:12:31:891_S:] AT+QSCAN=3,1
[2025-12-17 11:12:31:947_R:] AT+QSCAN=3,1
[2025-12-17 11:12:33:025_R:] OK
[2025-12-17 11:12:34:402_S:] AT+QSCAN=3,1
[2025-12-17 11:12:34:459_R:] AT+QSCAN=3,1
[2025-12-17 11:12:35:536_R:] OK
provide the solution
Dear @Shafique123
Do you insert SIM card? It is recommended to use the command when there is no SIM card.
