Yes, I connected it also now. sudo quectel-CM& -p #### outputs the following now:
[ main.c-0924: 03-10_10:06:46:892] QConnectManager_Linux_V1.6.5
[ device.c-0387: 03-10_10:06:46:892] network interface '' or qmidev '' is not exist
[ device.c-0628: 03-10_10:06:46:892] netcard driver = pcie_mhi, driver version = V1.3.8
[qmap_bridge_mode.c-0325: 03-10_10:06:46:892] qmap_mode = 1, qmap_version = 9, qmap_size = 15360, muxid = 0x81, qmap_netcard = rmnet_mhi0.1
[ main.c-0739: 03-10_10:06:46:892] Modem works in QMI mode
[ QmiWwanCM.c-0351: 03-10_10:06:46:900] cdc_wdm_fd = 7
[ QmiWwanCM.c-0177: 03-10_10:06:46:914] Get clientWDS = 14
[ QmiWwanCM.c-0178: 03-10_10:06:46:919] Get clientDMS = 1
[ QmiWwanCM.c-0179: 03-10_10:06:46:925] Get clientNAS = 3
[ QmiWwanCM.c-0183: 03-10_10:06:46:929] Get clientUIM = 2
[ QmiWwanCM.c-0185: 03-10_10:06:46:933] Get clientWDA = 1
[ QMIThread.c-2273: 03-10_10:06:46:938] requestBaseBandVersion RM520NGLAAR01A08M4G
[ QMIThread.c-0811: 03-10_10:06:46:941] qmap_settings.rx_urb_size = 15360
[ QMIThread.c-0820: 03-10_10:06:46:941] qmap_settings.ul_data_aggregation_max_datagrams = 11
[ QMIThread.c-0826: 03-10_10:06:46:941] qmap_settings.ul_data_aggregation_max_size = 8192
[ QMIThread.c-0832: 03-10_10:06:46:941] qmap_settings.dl_minimum_padding = 0
[ QMIThread.c-1027: 03-10_10:06:46:961] requestGetSIMStatus SIMStatus: SIM_PIN
[ QMIThread.c-2153: 03-10_10:06:47:056] requestGetProfile[pdp:1 index:1] data.tre.dk//dev/mhi_QMI0//0/IPV4
[ QMIThread.c-1692: 03-10_10:06:47:060] requestRegistrationState2 MCC: 238, MNC: 6, PS: Detached, DataCap: UNKNOW
[ QMIThread.c-1692: 03-10_10:06:47:064] requestRegistrationState2 MCC: 238, MNC: 6, PS: Detached, DataCap: UNKNOW
[ QMIThread.c-1827: 03-10_10:06:47:067] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[ udhcpc.c-0034: 03-10_10:06:47:067] ip link set dev rmnet_mhi0 down
[ udhcpc.c-0034: 03-10_10:06:47:069] ip addr flush dev rmnet_mhi0.1
[ udhcpc.c-0034: 03-10_10:06:47:070] ip link set dev rmnet_mhi0.1 down
[ QMIThread.c-1692: 03-10_10:06:47:974] requestRegistrationState2 MCC: 238, MNC: 6, PS: Detached, DataCap: UNKNOW
[ QMIThread.c-1692: 03-10_10:06:49:599] requestRegistrationState2 MCC: 238, MNC: 6, PS: Attached, DataCap: 5G_NSA
[ QMIThread.c-1875: 03-10_10:06:49:611] requestSetupDataCall WdsConnectionIPv4Handle: 0x17a687f0
[ QMIThread.c-1692: 03-10_10:06:49:621] requestRegistrationState2 MCC: 238, MNC: 6, PS: Attached, DataCap: 5G_NSA
[ udhcpc.c-0056: 03-10_10:06:49:629] change mtu 1500 -> 1460
[ udhcpc.c-0034: 03-10_10:06:49:629] ip link set dev rmnet_mhi0 up
[ udhcpc.c-0034: 03-10_10:06:49:632] ip link set dev rmnet_mhi0.1 up
[ udhcpc.c-0552: 03-10_10:06:49:634] No default.script found, it should be in '/usr/share/udhcpc/' or '/etc//udhcpc' depend on your udhcpc version!
[ udhcpc.c-0167: 03-10_10:06:49:634] busybox udhcpc -f -n -q -t 5 -i rmnet_mhi0.1
udhcpc: started, v1.30.1
udhcpc: sending discover
udhcpc: sending select for 10.168.178.96
udhcpc: lease of 10.168.178.96 obtained, lease time 7200
[ udhcpc.c-0034: 03-10_10:06:49:712] ip -4 address flush dev rmnet_mhi0.1
[ udhcpc.c-0034: 03-10_10:06:49:714] ip -4 address add 10.168.178.96/26 dev rmnet_mhi0.1
[ udhcpc.c-0034: 03-10_10:06:49:715] ip -4 route add default via 10.168.178.97 dev rmnet_mhi0.1
And the AT commands:
RDY
+CPIN: SIM PIN
+CFUN: 1
+CPIN: READY
+QUSIM: 1
+QIND: SMS DONE
+QIND: PB DONE
AT+QENG=“servingcell”
ERROR
AT+QIACT?
AT+CGDCONT?
+CGDCONT: 1,"IP","data.tre.dk","0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1,,,,,,,,,"",,,,0
+CGDCONT: 5,"IP","data.tre.dk","0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
AT+QCFG=“usbnet”
