RM520NGLAAR03A01M4G issue activating/reading NMEA from it's port
Hello
in AT manual is stated, that after AT+QGPS=1 NMEA can be read from GNSS serial port, in my case /dev/ttyUSB1 (Linux)
On the modem RM520NGL AA R03 it is not works, 1st activation give an +CME ERROR: 504 (which is normal, when GNSS already active, but it is not).
On earlier revision R01 it is working fine. (tested on RM520NGLAAR01A08M4G)
Any clues? Do I need a firmware fix or the command is changed?
Regards, Peter
AT+QGMR
RM520NGLAAR03A01M4G_A0.300.A0.300
AT+CVERSION
VERSION: RM520NGLAAR03A01M4G
Apr 18 2025 09:05:15
Authors: Quectel
AT+CSUB
SubEdition: V03
Revision: RM520NGLAAR03A01M4G
Dear @batcilla
I have sent a newer version to your email, please check.
Dear @silvia
Thank you very much, I am waiting for the USB2M.2 adapter to arrive to location with that modem.
Do I need a specific QFlash version to perform an upgrade or can use latest from website?
Dear @batcilla
It is recommended to use the latest version of QFlash to upgrde.
Dear @silvia
Thank you very much for the support and promt responces
