I have 2 Quectel modems that I am using with Linux:
1.) EC25-A
2.) RM520N-GL
I also have 2 SIM cards:
1.) eSIM from Globalgig
2.) T-Mobile (US) SIM
I want to use the eSIM with the RM520N modem. The eSIM does successfully work with the EC25A modem and BIP mode. The eSIM does not work with the 5G capable RM520N-GL. My T-Mobile SIM cards works great with the RM520N-GL and connects without BIP. I cannot find any BIP related commands in the AT command document for the RM520.
The following commands are what I successfully use with the EC25 to connect the eSIM using BIP:
atcom -p /dev/ttyUSB2 AT&F0
atcom -p /dev/ttyUSB2 AT+CFUN=0
atcom -p /dev/ttyUSB2 AT+CFUN=1
atcom -p /dev/ttyUSB2 AT+QCFG="roamservice",1
atcom -p /dev/ttyUSB2 AT+CMEE=2
atcom -p /dev/ttyUSB2 AT+CREG=1
atcom -p /dev/ttyUSB2 AT+QCFG="bip/auth",1
atcom -p /dev/ttyUSB2 AT+QCFG="roamservice",2
atcom -p /dev/ttyUSB2 AT+CGDCONT=1,"IP","internet"
atcom -p /dev/ttyUSB2 AT+CGACT=1,1
atcom -p /dev/ttyUSB2 AT+CGDCONT?
atcom -p /dev/ttyUSB2 AT+CREG?
When I try to run the same commands on the RM520, I see the following output (Note the BIP error):
+CPIN: READY
+QUSIM: 1
+QIND: SMS DONE
+QIND: PB DONE
+QTELEFONICA: “retry_schema”,“pdp_fail”,6,33,209
AT&F0
AT+CFUN=0
AT+CFUN=1
RM520NGLAAR01A08M4G_01.200.01.200
AT+QCFG=“roamservice”,1
ERROR
+CPIN: READY
+QUSIM: 1
AT+CMEE=2
+QIND: SMS DONE
AT+CREG=1
AT+QCFG=“bip/auth”,1
ERROR
+QIND: PB DONE
AT+QCFG=“roamservice”,2
ERROR
AT+CGDCONT=1,“IP”,“internet”
AT+CGACT=1,1
+CME ERROR: no network service
AT+CGDCONT?
+CGDCONT: 1,“IP”,“internet”,“0.0.0.0”,0,0,0,0,“”,0
+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0,“”,0
+CGDCONT: 3,“IPV4V6”,“SOS”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1,“”,0
+CGDCONT: 4,“IPV4V6”,“XCAP”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0,“”,0
ERROR
AT+CREG?
+CREG: 0,0
AT+CFUN=0
AT+CFUN=1
I then run the following commands to request an IP address in Linux:
dhclient -v usb0
udhcpc -i usb0
route add -net 0.0.0.0 usb0
The output for those commands is:
Internet Systems Consortium DHCP Client 4.4.3-P1
Copyright 2004-2022 Internet Systems Consortium.
All rights reserved.
For info, please visit ISC DHCP - ISC
Listening on LPF/usb0/ce:38:30:a3:26:82
Sending on LPF/usb0/ce:38:30:a3:26:82
Sending on Socket/fallback
DHCPREQUEST for 192.168.225.20 on usb0 to 255.255.255.255 port 67
DHCPACK of 192.168.225.20 from 192.168.225.1
bound to 192.168.225.20 – renewal in 19354 seconds.
udhcpc: started, v1.35.0
udhcpc: broadcasting discover
udhcpc: broadcasting select for 192.168.225.20, server 192.168.225.1
udhcpc: lease of 192.168.225.20 obtained from 192.168.225.1, lease time 43200
root@raspberrypi:/home/pi/Desktop# ping 192.168.225.1
PING 192.168.225.1 (192.168.225.1) 56(84) bytes of data.
64 bytes from 192.168.225.1: icmp_seq=1 ttl=64 time=1.57 ms
64 bytes from 192.168.225.1: icmp_seq=2 ttl=64 time=1.53 ms
64 bytes from 192.168.225.1: icmp_seq=3 ttl=64 time=1.54 ms
64 bytes from 192.168.225.1: icmp_seq=4 ttl=64 time=1.53 ms
So, it seems that the modem can get an IP address and ping the gateway. However, there is no internet connection (the same ping fails for google or any other public IP address). How can I enable BIP mode on the RM520 and get an internet connection in Linux with my eSIM? Thanks!
