Can i have the following files RM520N-GLAP? Thank you!
PCIE drivers for windows 10
Firmware for RM520N-GLAP (pcie only)
Windows software to send at command and cellular connect manager.
Dear @JT_JT
Could you share your current firmware?
The module no longer detected under Root Complex mode. Anyway to force fw upgrade via emergency mode or shorting pins to hardware reset? I cannot reset via reset button in enclosure.
Hi, could you share the windows 10/11 PCIE drivers for RM520N-GLAP? My RM520N-GLAP got recognized as an unknown PCI Device.
Please check the message.
I have same issue. When I change pci mode from EP to RC, it is no longer detected by lspci. How can I reset it to EP mode. Would you let me your solution?
Still no solution yet.
Dear @Gene_Chin @JT_JT
Did you install the module in laptop directly or CPE?
i tried both. but i accidentally run some AT command to usb mode then it stop detecting. i request the firmware for this or how to hard reset with running any AT commands. it is no longer detected by laptop.
It is in laptop for me.
Dear @JT_JT @Gene_Chin
Do you see any unknow USB device in device manager?
(post deleted by author)
no, this model does not have usb. please provide fw to email caliboi01@gmail.com. I cannot refer to my seller.
It is a PCIe model, No USB device can be found in both lsusb or device manager.
I can share the firmware to you, but I am not sure if it is ok after upgrade.
my module don’t work so i need the firmware please
netcutar@gmail.com
It’s appreciated if you can share both driver and firmware. Only if I have proper driver to recognize it and then I have chance to make it alive.
i hope they help us if they can
Dear @Md12
I have replied in other topic, please check.
thank you for the replay but i need any frimwere the module is not working anymore so maybe be i can revive it through edl i tried installing lenovo frimwere it accepts it but doesn’t show on windows after drivers install it was working before i missed with it .
