I am waiting to get the modem from Ali Express next week can you please send me everything I need to make it work with windows.drivers last firmware.and manuals
Hi @Bean.Wang-Q
Can you, pls, help me with root passwords for two RM520 modules?
First:
sdxlemur login: root
quectel-v : v1.0
quectel-ID : 21070531
And second:
quectel-v : v1.0
quectel-ID : 37099465
Thanks in advance!
Regards, Eugene
Enter the AT+QADBKEY? response: 21070531
AT+QADBKEY=“zd2atT2LXnfTHXF”
Enter the AT+QADBKEY? response: 37099465
AT+QADBKEY=“Sj.E40CWYy89zd1”
Tnanks a lot!!!
Regards, Eugene
please check the passcode~
Thanks!
Regards, Eugene
@Niki.Liu-Q Thanks for the codes!
It’s interesting, that first code (for 21070531) is ok, but second (for 37099465) is wrong (as system says).
Second modem has this fw: RM520NGLAAR03A03M4G.
Can you generate the passcode again?
Thanks in advance!
Eugene
HL07xwJ2dUoRYLum95uIJ0
hello, please check this one @elukyan
i would like to know this too! i have a rj45 enclosure coming in, and i’d like to know if there are any special steps for this, or will i just get a AT interface?
Was it successful to set Rm520n-glap to PCIE RC mode via AT command from debug port so it can stream internet from ethernet port?
Can you provide me with a password for the RG520 module?
quectel-v: v1.0
quectel-ID : 26407312
Password:
Login timed out after 60 seconds.
QTI Linux reference nogplv3 distro targeting performance builds.
LE.UM.5.3.2.x1-06300-SDX65.0 sdxlemur ttyMSM0
sdxlemur login:
Thanks in advance!
Hello Support Team,
I need help with UART/root login access for my RM520N-GLAP module.
When I connect to the debug UART and try to log in as root, the module shows:
quectel-v : v2.0
Login info:
Password:
The UART console itself confirms that the login challenge expires after 300 seconds. If no valid password/passcode is entered in time, it prints:
Login timed out after 300 seconds.
Because of this timeout, asynchronous exchange does not work: by the time support replies, the Login info has already expired.
Could we please arrange a short real-time support window with a Quectel engineer?
At the agreed time I will:
Generate a fresh Login info.
Send it immediately by private message or in this thread, whichever you prefer.
Wait online for the password/passcode and enter it before the 300-second timeout expires.
My timezone is Amsterdam time / CEST, UTC+2.
Please let me know a suitable date and time, and the preferred way to send the fresh Login info.
Thank you.
Hi @Niki.Liu-Q
Please help to check.
@ndrew_m Hello, as you said the validity period of the password is only 5 minutes,please send me the login info via private message.I will arrange a time with you via private message. Thanks a lot~
