Hello
I’m using 2 RM520N-GL UE modules with a 5G srsran gnb on n78band. I use MBIM and the 2 UEs have been upgraded to firmware RM520NGLAAR03A03M4G_A0.301.A0.301.
One of the UE can’t connect and gets the following output with 5g-nsa data class while the gNB is 5G-SA:
---- mbimcli -p -d /dev/cdc-wdm0 --attach-packet-service
[/dev/cdc-wdm0] Successfully attached to packet service
[/dev/cdc-wdm0] Packet service status:
Network error: ‘none’
Packet service state: ‘attached’
Available data classes: ‘5g-nsa’
Uplink speed: ‘1497000000 bps’
Downlink speed: ‘3951000000 bps’
---- mbimcli -p -d /dev/cdc-wdm0 --connect=session-id=0,access-string=streaming,ip-type=ipv4
error: operation failed: InvalidParameters
Here are the info on the UE:
Modem Revision: RM520NGLAAR03A03M4G
IMEI: 868371053148272
IMSI: 001010000000013
ICCID: 8986006110000000010
SIM Status: READY
APN Profiles / DNN:
+CGDCONT: 1,“IP”,“streaming”,“0.0.0.0”,0,0,0,0,“”,0
+CGDCONT: 2,“IP”,“streaming_EMBB000002”,“0.0.0.0”,0,0,0,0,1,“01.000002”,0
→ NSSAI: 01.000002
NSSAI Info: 01.000002
Network Info: TDD NR5G
Serving Cell: not found
USB Mode: 2 (MBIM)
Preferred Mode: NR5G
LTE Bands: 1:2:3:4:5:7:8:12:13:14:17:18:19:20:25:26:28:29:30:32:34:38:39:40:41:42:43:46:48:66:71
NR5G Bands: 1:2:3:5:7:8:12:13:14:18:20:25:26:28:29:30:38:40:41:48:66:70:71:75:76:77:78:79
4G Registration: 0,0
5G Registration: 0,1
AT+QNWPREFCFG=“mode_pref”
+QNWPREFCFG: “mode_pref”,NR5G
AT+QNWPREFCFG=“nr5g_band”
+QNWPREFCFG: “nr5g_band”,1:2:3:5:7:8:12:13:14:18:20:25:26:28:29:30:38:40:41:48:66:70:71:75:76:77:78:79
AT+QNWINFO
+QNWINFO: “TDD NR5G”,“00101”,“NR5G BAND 78”,640032
AT+QENG=“servingcell”
+QENG: “servingcell”,“NOCONN”,“NR5G-SA”,“TDD”,001,01,00066C000,0,1,640032,78,3,-106,-16,-5,1,34
at+qcfg=“usbnet”
+QCFG: “usbnet”,2
at+cgdcont?
I tried this type of reset but the problem is the same once I reconfigure DNN and NSSAI.
AT+QPRTPARA=3
AT+CFUN=1,1
What should I do to fix this issue ?
Best,
Thierry
