RM520N-GL with PCIe interface only?
The modules have PCIe and USB interfaces. They are initially only configured as a USB device and then have to be switched to PCIe.
But we don’t have a USB device.
Can the modules be operated with a PCIe interface only?
Best regards,
Werner
hi ,
You can use at+qcfg=“data_interface” to set whether the network port communication is USB or pcie.
thanks.
I purchased a model that I believe to be a fixed PCIe module, specifically the RM520NGLAP-M20-SGASA. I actually intended to use it with a USB-M2 Ethernet adapter. Is there no possibility of using the RM520NGLAA-M20-SGASA model with a USB-M2 or Ethernet-M2 adapter? Any help would be greatly appreciated.
Thank you in advance.
Also interested on this as well. Is there a way to revert back to USB mode?
It is definitely not possible, NGLAP is only Pcie.
