We are configuring two RM520N-GL modems connected via pcie under windows 11.
The modem has been configured with APN and Password.
The modem shows as registered / connected and has an IP address through the AT port.
An mbn profile with the APN and credentials has been added to the modem.
In windows the Quectel Wireless Ethernet Adapter is not showing as connected or having an IP address assigned. When manually connecting from windows it displays ‘can’t connect to this network Enter an APN and try again.’
What is the recommended way to configure the modem with an apn username and password when using via pcie in windows 11?
After reinstalling the drivers one modem is able to connect in windows. The other will not showing. ‘can’t connect to this network Enter an APN and try again.’
Are there any commands that be used to configure the windows driver?
Is there a different command that should be used other than AT$QCPDPP?
I can’t find any around setting the credentials and auth type in the AT command manual Quectel_RG50xQRM5xxQ_Series_AT_Commands_Manual_V1.2.
Commands Issued to configure modem
AT+CGDCONT=1,“IP”,“APN”
AT$QCPDPP=1,2,pass,user
AT+CGACT=1,1
AT+CGPADDR shows the expected ip address
Modem
RM520N-GL
Revision: RM520NGLAAR01A01M4GA
PCIE connection
Windows
OS Name: Microsoft Windows 11 IoT Enterprise
OS Version: 10.0.22621 N/A Build 22621
Version22H2 Build 22621.2861
64Bit.
Driver
Quectel_Windows_USB_DriverQ_NDIS_V2.3_EN-1
