I have a RN520N-GL (Firmware RM520NGLAAR03A03M4G)
Testing it with the RM520 Monitor software ( RM520 Monitor — Quectel RM520N-GL 5G Modem Monitor & Config Tool (Windows & Linux) ) everything is the same, except the GPS tab:
- On windows I have immediate detection of many satellites, a fix and accurate positioning
- On Raspberry PI i have exactly 0 satellites detected, almost like i had no GPS support or antenna
I also called all AT+QGPS and all AT+QCFG commands to see their values both on Windows and the Raspberry and they have all exactly the same values except the AT+QGPSGNMEA=“GGA” or “GSV” or “RMC”
I have it on a Waveshare PCIe to M.2 4G/5G and USB 3.2 Hat with a 5G-4IN1-PCB Antenna (Amazon.es) at first I thought it was the antenna, but on windows it catches more than 30 satellites, so that is not it.
So basically I tested it with:
- Raspberry connected as a HAT
- Raspberry through a USB cable (fully detached from the Raspberry HAT)
- Windows through a USB cable (using the same USB cable)
- Same exact position of the antenna, a few interleaved times, a few minutes appart with the same clear sky above
- Same “RM520 Monitor” java software, reports same 4.00V voltage, behaves exactly the same on everything except GPS
Main difference, besides operating system and main system hardware, is that windows had to install drivers and Raspberry access through /dev/ttyUSB2 without any need for drivers.
I tried everything I could think of, threw some AI agents at it to search over the internet and cogitate on all possibilities and always end up in circles.
It makes no sense at all, and I feel this is one of those Gettier problems that Murphy’s Law sometimes throws at us and in the end it is a missing comma somewhere.
Did anyone have this sort of problem already and how did you fix it?
