RM520N-GL - PDU Sessions
does the RM520N-GL support Ethernet PDU Session and/or Unstructured PSU Session?
If so, how do I activate either of them?
Thanks in advance.
Dear @K_Jacobs
It supports Ethernet PDU session, but it used for 5G LAN.
Do you network support 5G LAN?
At this time I use an private network. My colleagues and I are working close with the network’s technical staff to check if the neccessary options can be implemented in the network’s core.
We are still looking into possible use cases.
Dear @K_Jacobs
I have sent a document for reference via Message, please check.
I’m also working with the RM520N-GL to verify an Ethernet PDU session with our network. Could you please share the firmware version you’re using and any documentation or notes on how to establish the PDU session?
Thank you very much
Dear @tbs
Do you want to test 5G LAN? If yes, it doesn’t support.
