RM520N-GL latest firmware and drivers for Windows and Linux
sir… pls share latest RM520N-GL module latest firmware and drivers for both Window and Linux OS and AT command manual also.
my mail: manikantananda777@gmail.com
Dear @iotmani
I have sent them to you via Message, please check.
received… thanks for sharing
we are inserted RM520N-GL M.2 form factor module in Ubuntu OS system. Pls tell me how to communicate RM520N with AT commands via. Qcom or any other software is required?
Tq
Can you send the driver to my email? Now their employees are on vacation
yes i can. share ur mail details
just i shared to ur mail
yes, i got it. However, I don’t know how to refresh the firmware, after I switch the module to rndis mode and install the latest driver, I still can’t connect to the serial port under Windows
Could you please send me the latest firmware for RM520N-GL. Thanks roblittiken@gmail.com
You need to install minicom, for at commands on Linux.
What firmware version did you get, and what drivers?
Hello all,
I also need the latest drivers for Windows and the latest firmware if there is one more recent than RM520NGLAAR01A06M4G.
Also I would be happy about up-to-date documentation, the AT-Command list I have is from RM500, with this I am unsure if everything is still correct.
please sent it to: jonah.mons@brown-iposs.eu
Best Regards
Dear @boonex
Which driver did you install?You want to use RNDIS mode,right?
Dear @nekit
I have sent it to you vai Message, please check.
Dear @Jonah
Quectel_Windows_USB_Driver(Q)_RNDIS_V1.0 This version of the driver was obtained from your company’s technical staff and can perfectly drive the module in rndis mode
Please, I also need the latest drivers for Windows and the latest firmware
Can you please send me the following tools:
Qflash Tool: QFlash_Linux&Android_V6.2
QFirehose Tool:QFirehose_Linux_Android_V1.4.12
USB Driver: Quectel_Linux_USB_Serial_Option_Driver_20220622
Quectel-CM Tool: Quectel_QConnectManager_Linux_V1.6.4
QLog Tool: QLog_Linux_Android_V1.5.17
QMI_WWAN Driver: Quectel_Linux&Android_QMI_WWAN_Driver_V1.2.2
GobiNet Driver: Quectel_Linux&Android_GobiNet_Driver_V1.6.3
Thanks !
Dear @boonex
What is your peoblem? How to flash the firmware or others?
Dear @Pagan
Dear @Harbour
Currently, we use Qfirehose to upgrade in Linux, please ignore Qflsh and use QFirehose.
Other drivers have sent to you via Message, please check.
Hello, I still have one question,
is there a document that describes how to update the firmware ?
I have already done it with the RM500, however I do not want to make a mistake.
Best Regards
