I would like to report a potentially incorrect automatic MBN (carrier
configuration) selection on the Quectel RM520N-GL modem when using a
Magyar Telekom SIM in Hungary.
Hardware and software:
Module: Quectel RM520N-GL
Firmware: RM520NGLAAR03A03M4G
Host OS: Linux (ModemManager, PCIe/MHI interface)
Operator: Magyar Telekom, Hungary (MCC/MNC 216/30)
Problem:
The modem fails to register on the home network when automatic MBN
selection is enabled.
Previously, on an older firmware, the modem automatically selected
Commercial-DT-VOLTE (0x0A011F1F), which prevented successful
registration.
After manually selecting ROW_Commercial (0x0A010809), registration
worked successfully.
Following a firmware update, the problem returned. The modem now
automatically selects a different profile:
AT+QMBNCFG=“AutoSel”
+QMBNCFG: “AutoSel”,1
AT+QMBNCFG=“List”
+QMBNCFG: “List”,0,1,1,“DT_Netherlands_Commercial”,0x0A011FE0,202212061
The modem still contains the previously working profile:
+QMBNCFG: “List”,37,0,0,“ROW_Commercial”,0x0A010809,202111051
The same SIM works in another modem, and the RM520N-GL previously
worked with a SIM from another Hungarian operator (Yettel). The modem
has also worked while roaming abroad.
Previously successful workaround:
AT+QMBNCFG=“AutoSel”,0
AT+QMBNCFG=“Deactivate”
AT+QMBNCFG=“Select”,“ROW_Commercial”
AT+CFUN=1,1
Questions:
Which MBN profile is officially recommended for Magyar Telekom Hungary (216/30)?
Why does automatic MBN selection choose DT_Netherlands_Commercial for this SIM?
Is this a known issue with the current firmware’s MBN selection logic
or carrier mapping?
Can this be corrected in a future firmware/MBN database update so that
automatic profile selection works correctly, including when roaming?
What logs or diagnostic information would help your firmware team
investigate this issue?
I would prefer to use automatic MBN selection rather than permanently
forcing a generic profile, particularly because the modem is also used
while roaming internationally.
