RM520N-GL GPS update rate
Can you confirm the max allowed GNSS data update rate with RM520N-GL please ?
If 10Hz data update rate cannot be achieve which variant or other module can we use instead please ?
Regards
Dear @Dunaxis
For RM520N-GL, it supports 1Hz data update rate. Why did you want 10Hz?
Hi Silvia,
Our usecases need a 10Hz update rate and it’s also our customer needs.
Ok so this module doesn’t support the AT command, AT+QGPSCFG=“fixfreq” to set a higher update rate.
Can you give me others quectel products ref with the same spec as RM520N-GL but with a 10Hz update rate please ?
Regards,
Hello @silvia
Any update available please ?
Regards
Dear @Dunaxis
Currently, we don’t have module support 10Hz update rate.
