RM520N-GL flashing does not reset device
So I have a RM520N-GL that does not an AT, DM, or COM port communicating. I was able to get the module into EDL mode so QDownloader was available. I successfully flashed several different stock firmwares for this particular module, each says PASS, but when I restart the module I do not get an AT, DM, or COM port available. Is there any other way to reset a module to reverse whatever has been done to this device?
Please try to install the driver, I have sent it to you
Not sure if this specifically helped, but I did install it, reflashed really old firmware, then flashed into new firmware, and was able to run some AT commands. Thought I had everything set up in ECM mode, but I don’t have a connection with the internet through the ethernet port. eth_driver is r8125, usbnet is 1
The RM520-GL is up and running.
arifinzamantanz279@gmail.com
can you send me driver i have same problem facing
rm520n gl ethernet RTL8125 install but now not work at command not come cellular network not show.
and not show model . Emi . only ETH cable plug in internet work not any controls , i am firmware update not back to default,same problem . i need this solved ,and Port flashing,
Dear @imran_gazi
What do you mean? Windows driver? If yes, please download from website.
