Our service makes you feel bad, we are very sorry, because the company’s regulations are so, we need to work and implement according to the regulations
Thanks for that.
What is different R01A08 vs R03A03?
R represents the baseline version. If your module is R03, please upgrade the latest firmware of R03
Hello, can you please send me the latest and most up to date firmware for the RM520N-GL, and the updated linux driver? Thanks
My current revision: RM520NGLAAR01A08M4G
I have sent them to you
Good day! Do you also have the latest firmware for
RM500QAEAAR11A02M4G_01.005.01.005
? Im experiencing frequent disconnections especially in heavy bandwidth usage but others reported that it was already fixed with the newer firmware version.
I would like the latest firmware. Currently running RM520NGLAAR03A02M4GA.
Can you please tell me how to identify whether my module is R03 or R01? And, what is the difference between R03 and R01?
Please share the Linux and Windows driver for RM520-GLAP as well as the latest firmware and all tools? Thank you!
I have sent it to you
There are differences in the software versions of chipset, which are generally referred to as baseline version differences
Can you provide me with an RM520F-GL firmware?
RM520F-GL
RM520FGLBAR03A01M4G_01.200.01.200
Only this version is available
@herbert.pan-Q Can you send me the latest firmware for 520N-GL? I would also need the Linux tool (source or aarch64 binary) and document on how to use the linux tool to upgrade the firmware.
Here is the information about my hardware with “ATI” command.
RM520N-GL
Revision: RM520NGLAAR01A05M4G
email: zaihan@unrealasia.net
I cannot unzip the firmware. I have downloaded this 4 times but still failed.
╰─$ unzip RM520NGLAAR01A08M4G_01.202.01.202.zip
Archive: RM520NGLAAR01A08M4G_01.202.01.202.zip
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of RM520NGLAAR01A08M4G_01.202.01.202.zip or
RM520NGLAAR01A08M4G_01.202.01.202.zip.zip, and cannot find RM520NGLAAR01A08M4G_01.202.01.202.zip.ZIP, period.
╭─zaihan@ThinkPad-T14-Gen-2i ~/Downloads
╰─$ file RM520NGLAAR01A08M4G_01.202.01.202.zip 9 ↵
RM520NGLAAR01A08M4G_01.202.01.202.zip: Zip archive data, at least v2.0 to extract, compression method=deflate
I have also tried to use the GUI to extract. Still cannot.
Please try unzip on winOS system
Hi, I have a sample of the RM520NGLAP-M20-SGASA that I am currently testing.
I sincerely request the latest firmware and drivers, software and other tools that will work under Linux.
@herbert.pan-Q I would appreciate it if you could send me the files to my email address: mike.us.apple@outlook.com
Thank you!
Sorry, I can’t find this version of firmware
