I am using RM520N-GL (Q1-A9261).
how can I find out if the module is defective? I can’t get it to show up on a USB port in WIN10’s device manager. I have tested it with two different USB TO M.2 B KEY models.
Can you please provide the latest firmware, drivers and windows flash utilities for the Quectel RM520N-GL
Also looking for ABD key for RM520N-GL: +QADBKEY: 88342976
Current firmware installed: RM520NGLAAR01A08M4G_01.200.01.200
Good day. I hope youre doing good sir. Im also requesting for the latest firmware for RM520NGLAAR01A07M4G with windows driver and qfirehose so I can update it through a windows pc. Thank you!
I have sent them to you,pls check
How to enter the emergency boot and reflash the firmware
Can i get the ADB key for RM520N-GL? Thank you.
+QADBKEY: 29085668
How to enter the emergency boot and reflash the firmware. Can you send information please to:
Please can you re-supply the Windows drivers and firmware for the RM520N-GL? The existing link appears to be dead. Thank you.
Hello, I’d like to request the latest RM520N-GL Firmware please
I believe its the A08 revision now if I am not mistaken, RM520NGLAAR01A08M4G_01.200.01.200 ?
Can I please get the latest firmware and windows 10 drives for RM520GL?
Current firmware
RM520NGLAAR01A07M4G_01.201.01.201
Thank you!
Can I please get the most current firmware for the RM520N-GL?
I have read that the current version is
I have a firmware RM520NGLAAR03A03M4G_01.200.01.200, but honesty I don’t recall where I received it from. Will it also work on the RM520N-GL?
Can you please provide the latest firmware, windows flash utilities & AT Command sheet.
Quectel RM520N-GL Revision: RM520NGLAAR01A08M4G
edit: found it, so no more needed.
Thanks.
please send the last firmware?
actually i have this: RM520NGLAAR03A01M4G
marco.vanzetti@gmail.com
regards
Can i get firmware for RM520N-GLAP-M20-SGASA. This is PCIe only module.
Thank you.
Can you please send me the RM520N-GL latest firmware, latest Windows USB drivers, and update software for windows?
RM520NGLAAR01A06M4G
In addition fw for RM520N-GLAP. Can i get PCIE drivers for windows please?
Thank you.
I have sent them to your email,pls check
