I am testing Ethernet PDU / TSN on a Quectel RM520N-GL module.
Firmware version:
RM520NGLAAR05A01M4G_01.300.01.300
My goal is to make the UE send a PDU Session Establishment Request with Ethernet PDU type, or understand the correct AT command sequence required to do that on this firmware.
Supported commands shown by the module
AT+QMAP=?
The output includes:
+QMAP: "ETH_PDU",("enable","disable")
+QMAP: "connect",(0-3),(0,1)
+QMAP: "MPDN_status"
+QMAP: "MPDN_rule",(0-3),(1-16),(0,2-255),(0-3),(0,1),<IPPT_info>
AT+QNWCFG=?
+QNWCFG: "eth_cfg",(0,1),(1,2)
Current modem state
AT+QMAP="ETH_PDU"
+QMAP: "ETH_PDU","enable"
AT+QNWCFG="eth_cfg"
+QNWCFG: "eth_cfg",0
AT+QWDSCFG="profile"
+QWDSCFG: "profile",1,"IP","tsn",0,0
+QWDSCFG: "profile",2,"IPV4V6","ims",0,0
+QWDSCFG: "profile",3,"IPV4V6","sos",0,0
Commands I tried
AT+CGDCONT=1,"ETH","tsn"
Result:
ERROR
AT+QWDSCFG="profile",1,"ETH","tsn",0,0
Result:
ERROR
AT+QMAP="ETH_PDU","enable"
Result:
AT+QMAP="connect",0,1
In the failing case, result is:
ERROR
Behavior seen in signaling
On NGAP / NAS signaling trace, I can see:
successful registration
registration accept
registration complete
But in the failing Ethernet-PDU case, I do not see a PDU Session Establishment Request from the UE.
So it looks like the modem may be failing locally before it even sends the NAS request.
My questions
What is the correct AT command sequence on firmware
RM520NGLAAR05A01M4G_01.300.01.300to make the module request an Ethernet PDU session? -
Is
AT+QMAP="ETH_PDU","enable"alone sufficient, or is an additional command required? -
What is the meaning of:
AT+QNWCFG="eth_cfg" +QNWCFG: "eth_cfg",0and how should
eth_cfgbe configured for Ethernet PDU / 5G LAN? -
If
AT+CGDCONTandAT+QWDSCFG="profile"do not accept"ETH", how is the Ethernet PDU type actually configured on this firmware? -
Does this firmware fully support user-configurable Ethernet PDU / TSN / 5G LAN through public AT commands?
If needed, I can also provide full AT logs and signaling traces.
Thank you.
