I am using a Quectel RM520N-GL module and would like to know whether it can output a 1 PPS signal derived from cellular network timing.
Is PPS output based on 5G NR SIB9 or LTE SIB16 supported on this module?
If yes, does anyone know:
Which pin exposes this signal?
Whether the Quectel 5G-M2 EVB breaks out this pin?
Whether any special firmware or AT command is required?
If RM520N-GL does not support this, is there any recommended Quectel module and EVB for cellular-derived PPS output?
Thanks.
