RM520N-GL backup, upgrade firmware questions, manual AT-commands
Hello.
modem: RM520N-GLAA
firmware: RM520NGLAAR01A08M4G_01.200.01.200
board: MCUzone MR5210 v2
usage: 4G LTE
I’m going to flash the firmware from RM520NGLAAR01A08M4G_01.200.01.200 to RM520NGLAAR01A08M4G_01.205.01.205 (I have it on hand) or the latest version using QFLASH v7.5.
A) First, I want to find out a few questions about backup settings, IMEI and calibrations:
1)Which software will have a more complete or more reliable backup (QPST or QFIL)?
2) Which extension is more reliable to use for backup/restore in these programs .qcn or extended .xqcn?
3) If you use QFIL to backup calibrations, do you need to check “enable Multi-SIM” and change “storage type” in the lower right corner of the screen or is it enough that it is set by default?
4) Do I need a backup of MBN profiles (as I understand, full back up is needed by EFS) if I don’t use one in .200 firmware or will each newer firmware have a more expanded list of operators?
5) If something goes wrong during the firmware, do I need to make a full backup (EFS & etc.) or is this the same as the firmware itself?
B) I’m going to implement an adb script to reboot the modem with the command c AT+CFUN=1,1 when the PCI lines go down, but does the ADBKEY Unlock firmware support 01.205 or 01.206?
I read on the forum that not all firmware supports it…
C) I need the latest manual on AT commands that is relevant for the latest firmware versions 01.205 or 01.206?
D) Is it possible to upgrade in the future from 01.205 or 01.206 to lower firmware versions?
Dear @sgstriker
It use QPST to backup and restore QCN. You can use default extension when backup.
For firmware, it is recommended to use the latest firmware.
For backup document and AT commands manual, I will send to you via Message, please check later.
Hello, I am also working on backing up the RM500Q/520. I have already saved all current system settings before proceeding with the upgrade. Could you please provide the backup documentation and the AT command manual?
@silvia
ggmyzhanghu@gmail.com
Dear @Mr_Wanzi
