RM520N-GL - AT commands question
please clarify the below AT commands:
+QNWCFG: “dis_4mimo_enable”
+QNWCFG: “nr5g_4mimo_enable”
+QCFG: “diversity/config”
Situation: 2x2 MIMO antenna for LTE B1+B3, 2x2 MIMO antenna for NR5G N78
Both antennas pointed in different directions. Disable 4x4 MIMO for stability.
Is any change to diversity config necessary for this situation?
One antenna is connected to MAIN/DIV, other antenna to MIMO1+MIMO2.
Modem is R520N-GL, board is GL.INET X3000.
Side question: is there any AT commands that can have an impact on stability (network jitter, network latency) for improvement by disable IDLE for example?
Dear @navalcadet
Actually,+QCFG: “diversity/config” is used to test receive sensitivity, so you don’t need to configure this.
=>We don’t have these AT commands.
