RM520N-EU manual and CA-Combination excel
Hey.
Could someone send the RM520N-EU modem card data sheet and CA combination excel?
In EU model there is 5 antenna connector.
Are AT-command same in GL and EU?
Likewise, a hardware manual would be necessary, for this you can only find a manual and a data sheet for the global model on the website
Dear @darukza
I have sent hardware document and CA combination excel to you via Message, please check.
GL and EU use the same AT-commands.
Please for me the same, thanks!
Solved, send to me by private message.
Hi silvia,
could you send me them too please?
Thank you very much.
Dear @shv
I have sent the AT command manual to you.
For CA combination, due to strategy, I can’t send it to you, sorry about this.
I live in Europe and I still have to figure out if I should buy RM520N-EU or RM520N-GL. I’m very reluctant with the Eu version because seems to be much more limited, but, at the same time, many european users here reported GL not able to aggregate all bands.
So, how we can choose the right module when CA combinations are kept hidden?
The best suggestion I found here is to ask to the ISP: the ISP doesn’t even know what RM520N-GL and RM520N-EU are.
Dear @rm111
You can share the band which interested in, I will share part of them to you.
Good morning,
interested in a RM520N-EU module. I request the CA and MIMO combination valid for the following bands:
B1, B3, B20, B28, N3, N28.
And if possible even the last RM520N Series Hardware Design brochure.
Thanks in advance.
Dear @Tito_Benedict
Hello. I have a Cudy P5 router with RM520N-EU modem. Could I have list of supported CA combos when used with bands B1, B3, B20 and N28. Also is there difference in combos between firmware versions?
Dear @arihy
It is recommended to use the latest firmware.
