RM520 with ring cameras
I’m looking for some assistance. I’m wondering if anyone else is using the 5g m.2 rj45 board setup with ring cameras. Is anyone experiencing no live view through the ring app? Ever since I’ve been using this 5g m.2 rj45 setup, I haven’t been able to get it to work. Does it have anything to do with CGNAT? The live view never loads in the ring app, but i get notifications and alerts okay. Signal strength is good and app is up to date.
My setup is the 5g m.2 rj45 connected to a TP link AX21 router in router mode. I followed the awesome guide of iamromlan’s (GitHub - iamromulan/cellular-modem-wiki: Cellular Modem Knowledgebase) to setup my rj45 board.
my firmware and modem.
RM520N-GL
Revision: RM52ONGLAARO1AO8M4G O1.200.01.200
Thanks in advance.
Dear @todoroshi
Could you give us more information of your device? How to setup? It is better to give us a frame.
@silvia Hopefully this is what you meant. I setup my rj45 following the guides prompts.
AT+QCFG=“data_interface”,1,0
AT+QETH=“eth_driver”,“r8125”,1
AT+QCFG=“pcie/mode”,1
AT+QCFG=“usbnet”,1
AT+QMAPWAC=1
AT+CGDCONT=1,“IPV4V6”,“fast.t-mobile.com
AT+CFUN=1,1
Then
To enable IP passthrough (DMZ Method):
AT+QMAP=“LAN”,192.168.225.2
AT+QMAP=“DMZ”,1,4,192.168.225.2
AT+CFUN=1,1 (reboot)
Then
To enable IP passthrough (QMAP Method):
AT+QMAP=“MPDN_rule”,0,1,0,1,1,“FF:FF:FF:FF:FF:FF”
Then
DHCPV4DNS disable
AT+QMAP=“DHCPV4DNS”,“disable”
My setup is like so:
5g m2 rj45 → router → ring camera
(LAN → WAN → WiFi)
Dear @todoroshi
Did you try other device to connect with router? Is it work? like mobile phone can search via network or not.
I am not sure whether you can contact with ring camera’s provider and get any suggestion from them.
Thanks. I’ll contact ring.
