RM510Q-GLHA R8135 Slow
Hi
I have a RM510Q-GL on Google Fi. I have tried it in both Waveshare and MCUZone ethernet enclosures. Speed through Ethernet is limited to about 35-40mbps when using Ethernet in both enclosures. When connected with USB it gets 500mbps+.
Is there a newer firmware that fixes this?
AT+GMR
RM510QGLHAR11A03M4G 01.002.01.002
ATI
RM510Q-GLHA
Revision: RM510QGLHAR11A03M4G
Dear @Davis_McCoy
I have sent the firmware to your email, please check.
Please confirm the speed of ethernet port and cable, it also impact this.
The Ethernet port is set to 1000M and I have used several known good cables
Dear @Davis_McCoy
You can try to test with latest firmware.
Hi Silvia. This definitely seems to be better after testing. Can you please email me or send the most current AT command reference for RM510Q?
Dear @Davis_McCoy
