Does anyone have the latest RM510 firmware available? I am on RM510QGLAAR11A02M4G_01.001.01.001 currently and would like to update. I have the LP version.
hi,belusnecropolis:
The latest firmware version:RM510QGLAAR11A03M4G_01.001.01.001
https://quectel123-my.sharepoint.cn/:u:/g/personal/ae-fae_dom_quectel_com_cn/EVS1xlEd2_BDlFscJc_a_XUB8y3S2k7iumnz_axKmc4ZhQ?e=XwRZwf
@herbert.pan-Q any new updates sir? Thank you kindly.
The latest firmware currently released
RM500QGLABR11A06M4G_01.001.01.001.zip
@herbert.pan-Q this looks to be the RM500Q-GL firmware update. I need the latest RM510Q-GL update please.
Is there an AAR13 version with NR-CA available yet?
RM510QGL Latest released version
Do you need?
I need latest drivers of 510Q module
What type of driver do you need, Windows or Linux?
Both, if possible, I am comparing the performance
Hey @herbert.pan-Q is there a newer firmware than RM510QGLAAR11A04M4G_01.200.01.200 yet?
RM510QGLAAR11A04M4G_01.200.01.200 is the latest firmware version
Hello, i have a quectel RM510Q-GL. My current version is RM510QGLHAR11A04M4G_01.001.01.001
Can i please have the latest firmware drivers? I want for linux but if possible both linux and windows. Thank you
I have sent them to your email,pls check
Thank you very much!
Hello, i received the drivers thank you. My bad, i forgot to mention that i also need to update the firmware version of my modem to latest available version. Can you please provide also the firmware files so i can upgrade it if my current version is not the latest?
Current version: RM510QGLHAR11A04M4G_01.001.01.001
Hello, i noticed that the FW you sent me is the same with the one i have already. This means that i already have the latest version ? The reason i was looking for a FW update is because i can scan the NR network using this command at+qscan=2 BUT this command which is the command i need (at+qscan=2,1) scan with ext is giving error. Any ideas ? The command i found it from this Quectel_RG50xQ&RM5xxQ_Series_AT_Commands_Manual_V1.2 | Quectel Section โ5.23. AT+QSCAN Search Nearby Cellsโ
Dear @Philippos
The latest one is RM510QGLHAR11A04M4G_01.200.01.200.
The app version is different.
You can check AT+QSCAN=? to check the parameter.
Hi, silvia. I dug my RM510Q-GL out of the box and it appears I have the same issue. Could I get sent the latest FW?
Thanks!
Dear @rcarr
