I’m using RM510Q-GL with high power dev kit. I’m trying to get connection through 5G NSA which has band combination of b66 + n261. The UECababilityReport does not show 5G NR 261 information. LTE connection works perfectly. Seems like the UE is not measuring n261 at all. I have set LTE and 5G bands correctly. Any possibility that the n261 is somehow blocked by firmware?
What is the latest firmware and where to download? Or is there something what needs to be done for the high power antenna side/settings to get it working correctly?
Dear Sir,
Thanks for your question.
What is your current firmware?please take a picture about your EVB board.
RM510Q can support B66+n261 endc. Please kindly know it.
In order to better support you, please also help to answer below questions, thanks!
Company name and located city:
Project name (so we can refer to it in the future):
Application type:
Estimated Annual Units (for series production):
Project timeline:
Current status:
From which distributor do you buy Quectel modules & EVB kits?
Do you have EVB kit for this application?
Running FW is RM510QGLHAR11A03M4G.
Pictures attached from readymade setup and modem + HP antenna module
• Company name and located city: Nokia, Finland Oulu
• Project name (so we can refer to it in the future): n/a
• Application type: R&D
• Estimated Annual Units (for series production): n/a
• Project timeline: n/a
• Current status: Testing on hold due to UE problems to connect n261
• From which distributor do you buy Quectel modules & EVB kits? direct
• Do you have EVB kit for this application? yes
Br,
JaVa
