RM510Q-GL Firmware update
I have RM510Q-GL with Firmware RM510QGLAAR11A04M4G There is any new frimware ?
2.also i try so many time to do factory reset for the RM510Q-GL - Can any one help me with AT code or any isea to do Factory reset .
3. i try so many time to use ethernet drive throught RGMII but i canot get connection with my laptop
[2023-08-25_20:48:58:404]ATI
[2023-08-25_20:48:58:404]Quectel
[2023-08-25_20:48:58:404]RM510Q-GL
[2023-08-25_20:48:58:404]Revision: RM510QGLAAR11A04M4G
[2023-08-25_20:48:58:404]OK
[2023-08-25_20:49:30:097]AT+QETH=“rgmii”
[2023-08-25_20:49:30:097]+QETH: “RGMII”,“ENABLE”,1,0
[2023-08-25_20:49:30:097]+QETH: “RGMII”,1,1
[2023-08-25_20:49:30:097]+QETH: “RGMII”,0,2
[2023-08-25_20:49:30:097]+QETH: “RGMII”,0,3
[2023-08-25_20:49:30:097]+QETH: “RGMII”,0,4
[2023-08-25_20:49:30:097]OK
[2023-08-25_20:49:37:073]AT+QETH=“speed”
[2023-08-25_20:49:37:073]+QETH: “speed”,“0M”
[2023-08-25_20:49:37:073]OK
[2023-08-25_20:49:57:542]AT+QCFG=“usbnet”
[2023-08-25_20:49:57:558]+QCFG: “usbnet”,2
[2023-08-25_20:49:57:558]OK
[2023-08-25_20:50:05:804]AT+QETH=“eth_at”
[2023-08-25_20:50:05:820]+QETH: “eth_at”,“enable”
[2023-08-25_20:50:05:820]OK
[2023-08-25_20:50:13:682]AT+QETH=“an”
[2023-08-25_20:50:13:682]+QETH: “an”,“on”
[2023-08-25_20:50:13:682]OK
[2023-08-25_20:50:23:820]AT+QCFG=“data_interface”,1,0
[2023-08-25_20:50:23:820]OK
[2023-08-25_20:50:26:046]AT+QCFG=“pcie/mode”,1
[2023-08-25_20:50:26:062]OK
[2023-08-25_20:50:28:285]AT+QETH=“eth_driver”,“R8125”,1
[2023-08-25_20:50:28:285]OK
[2023-08-25_20:50:32:617]AT+QMAPWAC=1
[2023-08-25_20:50:32:649]OK
https://www.aliexpress.com/item/1005005714195628.html?spm=a2g0o.order_list.order_list_main.5.68381802QycWsO
i am actually having a similar issue i was able to set up the module in common mode and later in ip passwtrough but i have no idea what happened or what i did and now its always stuck in not configured although i can enable or disable rgmii :<m i would love if the support team would help me out and send me instructions on how to install a new firmware and give firmware to my email agamerawesome@gmail.com,
[the issue i have]
[2023-08-25 20:32:43:897_R:] OK
[2023-08-25 20:35:09:684_S:] AT+QETH=“rgmii”,“ENABLE”,1,1
[2023-08-25 20:35:09:690_R:] AT+QETH=“rgmii”,“ENABLE”,1,1
[2023-08-25 20:35:22:032_R:] ERROR
[2023-08-25 20:35:23:155_S:] AT+QETH=“rgmii”,“ENABLE”,1,0
[2023-08-25 20:35:23:161_R:] AT+QETH=“rgmii”,“ENABLE”,1,0
[2023-08-25 20:35:36:024_R:] ERROR
[2023-08-25 20:35:38:811_S:] AT+QETH=“rgmii”
[2023-08-25 20:35:38:818_R:] AT+QETH=“rgmii”
[2023-08-25 20:35:38:828_R:] +QETH: “RGMII”,“DISABLE”,0,-1
[2023-08-25 20:35:38:828_R:] +QETH: “RGMII”,0,1
[2023-08-25 20:35:38:828_R:] +QETH: “RGMII”,0,2
[2023-08-25 20:35:38:828_R:] +QETH: “RGMII”,0,3
[2023-08-25 20:35:38:828_R:] +QETH: “RGMII”,0,4
[2023-08-25 20:35:38:828_R:] OK
i do have bought the same developement board you have and the seller gave me these configuration options
1.PC上配置USB模式
AT+QCFG=“USBNET”,2
2.网卡切换为pcie模式
3.切换pcie为RC模式
4.切换网卡驱动为realtake 8111h
AT+QETH=“eth_driver”,“r8168”
5.打开自动拨号
AT+QMAPWAC=1
i just do not understand why the 4th one is not AT+QETH=“eth_driver”,“r8125”,1
What seller says is “for RTL8111H chip load r8168 driver”. Check which ethernet chip is installed on your board.
yeah i have the RTL8125 chip, problem is i am no longer able to enable the rgmii with data :< [i have no idea why]
